Results 1 to 20 of 20
Thread: Opened pool to green - need help please
    Feb 2015
    Grand Rapids MI
    53
    Hello everyone,
    Opened the pool this year and it came with a nice green mess in it. Wondering where I should go from here? I've run my numbers 2 days in a row (it was opened on Thursday, took numbers on Friday and Saturday). I just vacuumed it today. I also added 1 gallon of liquid chlorine (pool sanitizer - 10% sodium hypochlorite last night). The pool still looks just as green as when it was opened. Any suggestions for what I need to do to get this pool back in good shape? I'm keeping up with the filter, needing to backwash about every 12 hours. Also to note there are 2 skimmers and the main drain in the deep end does not work, so it takes a bit longer for my pool to turnover. I have the TF-100 test kit
    Here are my numbers from the past 2 days:
    5/20
    FC - 6ppm
    CC - 0ppm
    TC - 6ppm
    TA - 100 - 110 ppm
    CYA - 25 or 30
    PH 7.3
    Chlorine from blue box quick test - 1ppm
    5/21/16 after 1 gallon of liquid chlorine added and pool vacuumed
    FC - 14ppm
    CC - 0ppm
    TC - 14ppm
    TA - 120ppm
    Calcium Hardness - 100-125ppm
    PH 7.2 - 7.3
    Chlorine from blue box quick test - 1 - 2ppm
    Here are a few pictures of it as well.
    18,000 gallon in ground vinyl pool. Sand filter.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: Opened pool to green - need help please
    Keep circulating 24/7 and MAINTAIN SLAM level of FC for your CYA level.
    Feb 2015
    Grand Rapids MI
    53
    Thanks. Can you remind me where to find my SLAM level? And how long should it take to clear up with that being maintained? 3 or 4 days?
    Apr 2010
    East Texas
    9,600
    Chlorine/cya chart in pool school.
    Feb 2015
    Grand Rapids MI
    53
    And then just check and adjust once a day until clear?
    Apr 2010
    East Texas
    9,600
    AS REQUIRED! Or as often as you can. I'd say 4 hours or so apart.
    Feb 2015
    Grand Rapids MI
    53
    Also if I go over and use more chlorine than is listed is that bad?
    Quote Originally Posted by woodyp View Post
    Sent from my XT1030 using Tapatalk
    Gotcha thanks!
    Apr 2010
    East Texas
    9,600
    2 0r 3 ppm won't kill ya'.
    Feb 2015
    Grand Rapids MI
    53
    Another question. Why does my FC = 14 ppm and CC = 0 but when I do the quick test from the blue box it says chlorine is at 1ppm. Can you tell me the difference and which one I should pay attention to?
    Apr 2010
    East Texas
    9,600
    Scratch the blue box tester and go with the dpd powder test
    Feb 2015
    Grand Rapids MI
    53
    Thanks, I'll rely on that.
    Feb 2015
    Grand Rapids MI
    53
    Another question. I took the FC test that registered at 14ppm around 2pm today. I just took it again at 8pm and it still is 14ppm. Full sun all day on the pool. The water doesn't look any better. Any ideas of how to proceed?
    Apr 2010
    East Texas
    9,600
    Keep at it until you've passed all 3 SLAM criteria.
    Feb 2015
    Grand Rapids MI
    53
    Still at it today. I lost FC overnight was down to about 4 or 5ppm by 1pm today. I added 2 gallons of liquid chlorine then and turned on the pool robot to vacuum. I just tested FC again at 3pm and it was at 5ppm. I again added 2 more gallons of liquid chlorine. Am I not adding enough? The pool has been in full sun again today. Here is another picture. It does seem to be getting more blue than green but still very cloudy and just taking a lot of time. Is this also due to not having the main drain working, it will just take longer?
    Feb 2015
    Grand Rapids MI
    53
    Just tested my numbers again and they are at:
    FC - 13
    CC - 3
    TC - 16
    Is this bad to have CC's going up? What does it mean?
    Apr 2010
    East Texas
    9,600
    CCs mean you're killin' stuff!
    Feb 2015
    Grand Rapids MI
    53
    Well that's a good thing!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    I see a big color change with the two pics! Good job!
    The most important part of the SLAM is M=maintain as in maintain the FC level for your CYA level. Test and redose at least 4 times at day. More often if you can.
    Keep taking pics each day so you can see the difference. That will help yo KNOW it is working!
    Kim
    Feb 2015
    Grand Rapids MI
    53
    Thanks Kim! Good point with the pictures, sometimes it's hard to remember if it is actually changing or not!
  20. Back To Top    #20
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by jandersen13 View Post
    every day at the same time take a picture looking down at the steps. Wide angle shots like you are a taking can be deceiving. Looking down at the steps shows the water clearing better as you see the depth come in to view.
    Support the site
