Thread: Smooth and shaft seal question
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,871
    We are in process of replacing a Hayward motor and shaft seal. Question.......the instructions in the seal package say to never use PTFE or silicone products to lubricate. That's exactly what the pool supplier sold us. Is it a serious issue to not use what they sold us?
    subject got auto corrected. Sorry.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,833
    Re: Smooth and shaft seal question
    If you lubricate a mechanical seal chances are it leak leak and likely break. Silicone grease is for the o-rings in the pump body.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
