So it is my first open. Just want to verify what I need to do.
Vinyl Pool, 24200 estimated gallons
Using TF-100 test kit
FC 5ppm
CC 0ppm
TC 5ppm
TA 160
CYA 50, maybe 55 I know this a little subjective
Calcium hardness 175ppm
PH 7.6
Bromine 10
I balanced before I closed and used Dohenys floating winter release thing(I'm new so I don't know if that was a good idea) in the pool all winter
I still have maybe a half hour/45 minutes to fill so actual numbers should come in slightly lower. Wanted to test before it started raining.
Pool math tells me to add 101 oz of 6% bleach
PH is fine it says
CYA is on the high end but falls pretty much in?
CH is fine, though I guess this is really more for non-vinyl pools?
Do I need to bring my TA down?
FC 5ppm
CC 0ppm
TC 5ppm
TA 160
PH 7.6
Bromine 10
PH is fine it says
