Results 1 to 11 of 11
Thread: CYA testing
    Apr 2016
    Aliso Viejo/CA
    6
    CYA testing
    Water Testing Instructions on One Page vs Extended Test Kit Directions vs TFTestKits supplied instructions all say something different on how to mix R-0013 with pool sample.
    Supplied instructions say, "Mix then wait at least 30 seconds. Shake once more."
    Extended Test Kit Directions say, "Cap and then shake the mixing bottle for 30 seconds."
    Water Testing Instructions on One Page says, "
    Shake about 30 sec; let stand 2-3 minutes; briefly shake again."
    I understand that it may not make a difference but in my messed up mind these three statements say very different things.
    And as subjective as everyone makes this test out to be these discrepancies are a splinter in my mind
    13k gallon SWG IG plaster pool and spa with Pentair 60 sq ft D.E. filter and HAYWARD NAVIGATOR
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: CYA testing
    Ummmm.........they're all the same thing?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: CYA testing
    you're right
    I never noticed it before.. I mix for 30, let sit for 30, pour into 25ml tube and pour back and forth to the black dot tube
    Apr 2016
    Aliso Viejo/CA
    6
    Re: CYA testing
    Thanks guys.
    Once mixed and I perform test, can I save the rest of the solution till next week for a retest?
    30,419
    Re: CYA testing
    Quote Originally Posted by danbergstrom View Post
    Thanks guys.
    ?????? I am not sure how that is helpful. Am I misunderstanding what you are saying?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: CYA testing
    I am going to say no, doing anything a week later with reagent and pool water is not beneficial.
    I always mix and put it down for 30+ seconds while I test other stuff.
    Apr 2016
    Aliso Viejo/CA
    6
    Re: CYA testing
    So I mix R-0013 with pool sample and test for CYA.
    I still have over half the mixture left in the red capped bottle.
    Pool Calculator tells me I need to add 1 quart.
    After adding the quart I will retest next Saturday.
    Can I use the left over mixture?
    thanks
    thanks pooldv
    Aug 2014
    Northern IL
    4,615
    Re: CYA testing
    If you are adding liquid CYA, you can test within a few hours. Don't keep your old sample. That would not reflect your current pool water.
    30,419
    Re: CYA testing
    I am so puzzled by this....
    1. It seems you are saying that you will take old samples and test again next week. The water will have changed so why in the world would you use old samples when they will not reflect your current condition.
    2.
    Pool Calculator tells me I need to add 1 quart. After adding the quart I will retest next Saturday.
    Add a quart to accomplish what? What target are you trying to achieve?
    Apr 2016
    Aliso Viejo/CA
    6
    Re: CYA testing
    Duraleigh and MarionParoo are right. I would be retesting an old sample. duh
    duraleigh,
    Add a quart to get my CYA to 80.
    thanks all!
    Aug 2014
    Northern IL
    4,615
    Re: CYA testing
    Is your pool clear? If not, hold off on adding the CYA.
