Results 1 to 11 of 11
Thread: Stains respond to NOTHING
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Hey y'all. Haven't posted in awhile but you probably knew I would be back A few years ago I noticed a couple of stains in the shallow end. They did not respond to Vit C nor pucks. With my pool surface I was the only one who noticed so I let it go. Probably should have added a sequestrant but that's hindsight Last year I noticed more and some on the side close to the shallow end return. Thought, O.K. better put a stop to this Knowing they didn't respond to either of the above mentioned I tried the AA treatment anyway. This was Wed. 4.5lbs AA, 18 oz. Poly 60. Nothing happened. Didn't even lighten them. I added 2 quarts of sequestrant Thurs. evening. Held a cut lemon on one of them for 30 mins this a.m. NOTHING. If is is cobalt staining, what will get rid of them?
    My #'s this morning:
    pH 7
    Cl 0
    CH 200
    TA 50
    CYA 40
    Salt 2420
    Temp 70
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Stains respond to NOTHING
    Here are some pics of the stains
    Lynn
    JoyfulNoise's Avatar
    May 2015
    13,265
    You might want to consider using Jacks Magic StainID Kit.
    Why would you think it was cobalt staining??
    Matt
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    One winter I let my CH get down to around 100. Maybe poor gelcoat? Just not sure why they wouldn't respond to Vit C nor the puck?? What would the stain kit tell me that I don't already know? They feel rough compare to the rest of the pool surface. Almost like hardened tar is the best way I can describe it.
    Thanks for the reply Matt
    Lynn
    May 2015
    13,265
    It will help to differentiate between organic stains, iron & cobalt, copper and calcium scale. Once you know which it is, Jack's Magic has a variety of different chemicals to help remove them.
    See here - http://www.jacksmagic.com/pdfs/Stain-ID-Kit.pdf
    Matt
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    But wouldn't the AA, lemon, or puck at least made some sort of difference if it were any of those stains????
    I think I've read every thread on here about stains Seems most get results with citric acid or pucks. But noooooooooo, not me.
    Lynn
    May 2015
    13,265
    Old copper stains that have converted to CuO are very difficult to remove with either AA or citric acid. By the way, a lemon is only going to have a very small amount of citric acid in it, hardly enough to be useful.
    Matt
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Is it possible to remove them(if it is old copper) or is this something I will have to live with and continue to use sequestrant?? Didn't know that about lemons. But crushed vit C in a sock didn't budge them either.
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Another question. Will the sequestrant affect my CH #'s??? BTW. My numbers are usually spot on according to TFP. These #'s are just because I'm dealing with these dang stains. I've always had a pH of about 7.6. Should I try to keep that down some due to the staining? If so what??
    Lynn
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Try putting a vit C tablet on the stain for a couple or few hours and see what happens. For 11 or 12 bucks I agree that the Jacks stain kit is worth a shot.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks. I will give it a try and get the kit.
    Lynn
