Results 1 to 8 of 8
Thread: TA r0008
    Aug 2014
    NJ
    435
    TA r0008
    My R0008 bottle (which turns the sample green) was having trouble getting the drops out, so I picked the opening with a fork to make it easier for the drops to come out. But now it seems like the drops may be a bit bigger. Would bigger drops of this regent have an affect on the TA test?
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    OTPirate's Avatar
    Oct 2013
    Creedmoor, NC
    1,154
    Re: TA r0008
    Yes, you want the drop size that comes out of the original dropper. Email me at tftestkits@gmail.com and I can get you a new bottle of R-0008 OR a new dropper immediately. Sorry, you may have had a defective dropper and I want you to get the correct one.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: TA r0008
    Yeah.that test is ticky on the drop size.
    Aug 2014
    NJ
    435
    Re: TA r0008
    Thanks. I just emailed you OTPIRATE.
    Donldson's Avatar
    NW Ohio
    2,905
    Re: TA r0008
    Ok, I understand the R0009 drop size is important, but is it really vital for the R0008?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Aug 2014
    NJ
    435
    Re: TA r0008
    Just out of curiosity would more drops of R0008 make the TA higher or lower
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,755
    Re: TA r0008
    R-0008 is an indicator dye. More or less will only lighten or darken the hue and will not change the TA reading. Of the 3 reagents for TA, R-0009 is the only one where drop size truly matters.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    30,426
    Re: TA r0008
    The idea behind the dropper tip (on all the reagents) is not the size of the opening. It is the surface tension of the drops as the fluid comes out of the dropper tip.
    The tip is designed to "hold" the fluid on the end until gravity overcomes the surface tension and it falls off the tip.
    Regardless, poking a fork in it will result in little help......let it fall naturally.
