Thread: pump sucking air
    Apr 2014
    Brookfield, CT
    17
    pump sucking air
    I was having problems with low flow and air sucking into my hayward superpump. My trusted pool guy found the pump impeller was fouled with debris, cleaned it out, problem solved.
    21' x 41' vinyl in ground pool, 26500 gal. 1 hp Hayward pump, 4 wheel suction side The Pool Cleaner, Hayward EC-75 DE filter, Hayward SUMXL 140 heat pump, TF100 test kit with stirrer.
    Jun 2014
    15,118
    Re: pump sucking air
    Good for you Don! Now on to more important things ....
