Thread: Need advice on what to build up and level surface behind waterline tiles.
    May 2011
    Loveland, Colorado
    16
    I have a gunite pool that I fiberglassed with fiberglass fabric sandwiched between two coatings of epoxy (Pilgrim Permacoat, Inc PLASTIC product). It has held up great, really, for 11 years. Now it's starting to peel away from the top where I had a stone mason level the surface where the waterline tiles had fallen off. I think he just used mud...and it failed. Now I have to tear out all of the fiberglass and old tile (we ran the epoxy and glass right over the tile that was still there and it held perfectly). It's the areas where the original tiles had fallen off that were mudded and then failed. I want to install waterline tile. So I'll cut the epoxy/glass down below where the tiles will be and demo all of the old tiles and such.
    My question is this. What product do I use to fill-in and level out the surface below where the tile will be? I am thinking there will be some big gouges and gaps and such that will need to be filled in prior to applying the thinset and tiles. And, is there a recommended thinset for pools?
    Thanks.
    20x40 Gunite
    45,000G
    Resurfaced in 2005 with Epoxy Glass
    Hayward Super II
    Apr 2013
    Sacramento, CA
    2,769
    Re: Need advice on what to build up and level surface behind waterline tiles.
    There is no recommended thinset for pools. Depends on the type of tile and your surface. Different installers use different products. I would not say there is a consensus.
    Some (expensive) specialized suggestions:
    http://www.laticrete.com/Portals/0/d...s/lds252.0.pdf
    http://www.laticrete.com/Portals/0/d...ts/lds6770.pdf
    Apr 2013
    Sacramento, CA
    2,769
    As for filling the holes normally I would say plaster but you are not doing plaster so I would use this:
    Rapid Set 55 lb. Mortar Mix-04010055 - The Home Depot
    I can get this in California but all of this may be special order where you are. I like it because its sticky, and you can control the set time and is easy to mix in small,l batches.
