Results 1 to 11 of 11
Thread: Adding Solar Salt
    Jul 2015
    Miami, Fl
    31
    Adding Solar Salt
    I have been reading up about the itchy feel while in or out of the pool and Solar Salt should help. I was thinking of adding one bag, but my current salt levels range between 3500 - 3800. After adding the solar salt, do I lower the desired output knob on my Hayward system or leave it as is? Thanks in advance.
    JoyfulNoise's Avatar
    May 2015
    13,217
    Re: Adding Solar Salt
    Why would you add more salt to a pool that already has sufficient salt levels? Solar salt is just salt, nothing else. An additional bag will make no difference in feel.
    Matt
    38,305
    And it would not change the SWG output either.
    Jul 2015
    Miami, Fl
    31
    Just basing my thread on what others have said in other threads that by adding solar salt would help with the itching feeling we are experiencing while in the pool.
    May 2015
    13,217
    Yes, but you'd already be getting the benefits of salt since your pool already has salt in it. There is absolutely no difference between "solar salt" and pool salt. They are both high purity NaCl.
    If you're experiencing some difficulties with the feel of your water, and if you don't have one, I suggest you get one of the test kits we recommend and post up water test results. Often times, itchiness is a sign of water chemistry problems.
    Matt
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You already have plenty of solar salt in the pool. Adding one more bag won't change the feel of the water.
    chiefwej
    Jul 2015
    Miami, Fl
    31
    Can you share which exact kit I should get? I normally have my local pool store do the water tests reason why I don't have a kit. Thanks again
    May 2015
    13,217
    A K-2006 from Amazon or a TF-100 from TFTestkits.net. Either one will be fine.
    TFP does not trust pool store testing as it is often inaccurate and the ad vice based on it is often dead wrong. It is our contention that the pool owner is the only one that truly cares about their pool. Everyone else is simply trying to make money off of it. You'll notice that many times pool store testing is often accompanied with a print out of the corrective actions you need to take and a list of chemicals you need to buy. The chemicals are often more expensive versions of stuff you can find in your local supermarket, big box store or hardware store. The tests always tell you something is wrong and always instruct you to buy overpriced pool store chemicals.
    When you test your own pool water yourself, you then know exactly what your pool needs and you can come here for the very best advice....for free!
    Matt
    Jul 2015
    Miami, Fl
    31
    Thank you very nuch
    Aug 2010
    Dallas, TX
    4,052
    I don't believe the K-2006 or TF-100 contain salt tests. It is an optional add-on.
    I recommend the drop type test, as it is easier to get accurate results.
    Taylor Salt Test
    May 2015
    13,217
    Quote Originally Posted by RobbieH View Post
    Taylor Salt Test
    If you order Taylor p/n K-2006-S, the "S" signifies to add on the salt test reagents. Obviously it will be more expensive.
    Matt
