Results 1 to 19 of 19
Thread: New gauge questions
    Sep 2015
    Rome, NY
    363
    New gauge questions
    When they installed my pool, the Hayward gauge always read 28 psi. They told me to backflush when I got down to 18. I never realized the gauge should be zero until being a part of this forum.
    Now with the new gauge, it reads 15.5. Do I wait until it is at five before backflushing or is there a chance that it is already lower than it should be and needs to be back flushed ?
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    30,403
    Re: New gauge questions
    All gauges should read "zero" when the pump is off. Are you saying that your's reads 15.5 with the pump off?
    Sep 2015
    Rome, NY
    363
    Sorry about that. It reads 15.5 when the pump is running. The new one I got from you guys shows 0 off. So I guess my question is 15.5 good? Do I wait till it's at five before I backflush? Or does that pressure tell me needs to be backflush now ?
    30,403
    You seem to have it a bit backwards. The dirtier the filter gets, the HIGHER the pressure will be.
    Right now, you need to establish your "Normal Low" Do so by backflushing rinsing and then going back to filter and (remember/write down/note) that normal low.
    As you run the filter, the psi will slowly climb and you should back flush again when the psi rises by 25%
    So if you started at 15.5 as your normal low, then your signal to back flush would be 15.5 x 1.25% = roughly 20psi
    Sep 2015
    Rome, NY
    363
    Understood. Thx.
    Sep 2015
    Rome, NY
    363
    Still 15.5 after backflush and rinse.
    30,403
    So, you have a reasonable starting point. Each time I pass my filter, I take a quick look at the gauge to see if all is normal. You may not have to backwash for a long time.......that's good!
    Sep 2015
    Rome, NY
    363
    Thanks. Love this site and my TF100. It is calming
    Sep 2015
    Rome, NY
    363
    Anyone tell me why my gauge is now reading only 13 when running?
    no visible leaks.
    Still reads 0 when off.
    Jun 2014
    15,008
    Those gauges are good, but you can still have a little fluctuation from time to time based on your pool's water flow. You were at about 15 psi before, so perhaps your filter system and sand are settling-in and acclimating to everything resulting in a little drop. If you had a big drop we might be concerned about water flow, suction line blockage, etc from the pool to the pump. But I don't think that's case with you at this time. I would just monitor it from time to time. Remember, it will always read 0 when off - no movement of water, no pressure to the filter, therefore no psi.
    Sep 2015
    Rome, NY
    363
    Thanks again. I made the comment about 0 since my last one always read 10
    Sep 2015
    Rome, NY
    363
    Six month old gauge now reading 15 when off. Turn pump off and it shoots over 30.
    I took plumbing off and there is flow and backflow as appropriate so I'm thinking it has to be the gauge.
    Anyone know of one that lasts longer than six months?
    heres the one I have
    TFTestkits.net
    30,403
    Of course, TFTestkits will replace your gauge. All you needed to do was ask.
    Your post is confusing
    I assume you mean it goes over 30 when you turn the pump on, correct? and I also assume that when you shut the pump off the gauge goes to 15 and stays there.
    Curious......do you remember when it started doing this?
    Sep 2015
    Rome, NY
    363
    Just noticed the other day. I have not had the pump running for the last three weeks.
    Sorry about the confusion. Yes, when the pump is off or I remove the gauge it is it 15. When I turn the pump on it goes over 30.
    Gorgeous day out, so I wanted to test and then remove the plumbing.
    Sep 2015
    Rome, NY
    363
    Rebecca is sending me another one.
    22,542
    Just curious, how many days below freezing have you had this year?
    Sep 2015
    Rome, NY
    363
    Two? No hard freezes. Pump running as usual.
    30,403
    Two Hard Freezes in Rome, NY?? Isn't the average low around 10 -15 degrees most all winter? I knew some folks there years ago.
    Sep 2015
    Rome, NY
    363
    Yes, nothing yet this year though. 25 was it and then warmed up to 60.
    So cold the last few that it barely snowed!!
    other years we get slammed.
