Thread: Noob AGP numbers
    May 2016
    Baton Rouge, Louisiana
    1
    Noob AGP numbers
    Hi, and thanks in advance.
    This is the 2nd season for our 18' round, 48" deep above ground pool, with paper filter. I let it get pretty nasty before replacing the water and cleaning the pool a few weeks ago. I have only recently begun testing, and I want to make sure I am on the right track. This morning:
    5.5 FC
    7.2 PH
    170 TA
    20 CH
    20 CYA
    Does anything stick out here? In pool math, I use a depth of 3.8 feet. I have added muriatic acid a couple times to lower ph, and I added stabilizer about 4 days ago (so I'm not sure about the accuracy of the cya reading). I recently purchased a pool vac to help with the "fine" debris. My water is a bit cloudy right now.
    30,403
    Re: Noob AGP numbers
    Welcome to the forum.
    Add enough CYA to get to 50 ppm. Your pool will consume a LOT less bleach.
    FC, TA and pH are all fine.
    20 CH is surprisingly low but it doesn't matter much in a vinyl pool. I would probably raise CH to around 250 but it can wait a few weeks.
    Keep the cold ones close by and go swimming!
