Results 1 to 7 of 7
Thread: AP Report: Health Problems Found in 80% Of Public Pools
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    In the paper today.
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    30,419
    Re: AP Report: Health Problems Found in 80% Of Public Pools
    Of course, this is for public pools. We TFP'rs NEVER let our pools get in sketchy condiotions, right?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    But, we aren't kidding when we say to never let your chlorine level drop below minimum for your CYA level or your pool will be unsanitary with increased risk of person to person disease transmission. Algae will grow too.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Public pool chemical regulations seem completely arbitrary.
    My county requires 2-5ppm FC, and 50ppm maximum CYA. I guess maximum CYA levels are a good start...but 5ppm maximum FC level doesn't make much sense.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    May 2016
    MD
    195
    So... who here came up with the CYA numbers and level of FC to keep in the pool?
    I get the pool places just want to sell you stuff... so maybe they don't want it healthy, but he told me i need the FC under 5 even though the CYA is 80 ish... like CYA didn't even matter to them...
    IG, 25k gallons, 20x40 ft, Plaster, Pentair sand filter, variable speed pump, have a well, TF-100 test kit, Speed Stir
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by Puppiesonacid View Post
    Chemgeek proposed the FC/CYA ratios listed here, backing it with quite a bit of research.
    If you have your propeller hat handy, you can jump down the rabbit hole here: Pool Water Chemistry
    So why doesn't the pool industry acknowledge science? I think it's some combination of "stuck in their ways", and not wanting to lose sales on stabilized chlorine which have higher profit margins than liquid.
    Test Kits:
    My Pool:
    Donldson's Avatar
    NW Ohio
    2,894
    The FC/CYA idea originated with Ben Powell, who used studies, talks with chemists, and his own personal data to come up with an early version of the chart. Richard Falk (chem geek) polished it up and put together the chart we still use today.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
