Thread: Pentair IC 40 - Waffle like insert which end?
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    On my Pentair IC 40, I have a waffle like insert that came with the cell. Very dumb question but which end to I insert it in? I'm guessing the Inflow side to prevent large debris from entering the cell but since the cell is after the filter I think very little chance of this happening. Or maybe to minimize turbulence? On Youtube videos for cleaning the cell I never see this part and I'm really sure why? Is it necessary and what purpose does it serve?
    40x15 IG, 19,000 gallons, Taylor K-2006C, Intellichlor IC40, Pentiar 1.5 hp Intelliflo VS, Pentair 420 Clean/Clear Filter, Speedstir, Stonescape - french grey, Travertine Paver decking, Completed August 1, 2015.
    Jun 2014
    15,205
    Re: Pentair IC 40 - Waffle like insert which end?
    I see nothing about it in the Pentair manual either. Like you , I would assume the intake side, but interesting it's not even addressed at all. Maybe give them a call when they're open?
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    I will call them thanks. Like you I did not see it in the manual either.
    Kit Contents
    - One IntelliChlor Electronic Chlorine Generator
    - Two (2) cell union with two (2) o-rings
    - User’s Guide (this manual)
    That is it.
    JoyfulNoise's Avatar
    May 2015
    13,236
    Inlet side. It's meant to capture anything large before it hits the cell.
    Matt
    espejo's Avatar
    Nov 2014
    Kingwood Texas
    148
    Thanks JoyfulNoise. I would have thought anything that large would have been picked up by the filter upstream.
    May 2015
    13,236
    It's there in case you run a filter with an MPV that has a recirculate option. Recirculate bypasses the filter and can allow larger stuff to get through.
    Believe it or not, I found a scorpion tail (just the tail) stuck to the waffle screen the very first time I opened up my SWG. No idea how something like that could have gotten there as I have a DE filter and no MPV. Since it was the first year of operation, I can only assume the scorpion was in the plumbing after the filter.
    Matt
