Thread: First Closing/Opening TFP Method
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    Hello all. Glad to be back here and I see the forum is buzzing!
    Overall I have had a pretty uneventful opening this season since closing the pool last season according to the advice given here. But have a few questions regarding my opening test results. The water was a tad cloudy right after opening but after topping off, adjusting FC, pH, TA, brushing and running the filter for a few hours the clarity and sparkle was back.
    Closing tests results: Early November
    FC 16
    CC 0
    (taken prior to raising to shock level)
    pH 7.2
    TA 90
    CH 225
    CYA 40
    Salt 1700
    Borate 50
    Opening test results: Mid May
    FC 3
    CC 0
    pH 7.4
    TA 50
    CH 100
    CYA 0
    Salt 1200
    Borate 15
    Ammonia 0
    The water was not circulated prior to testing but I did brush a bit. Is the drop in CH, CYA and Borate expected in a covered pool over about 7 months?
    5900 gal Oval 17' x 12' x 54" Sharkline Navigator 54 AGP; 1.5 HP Hayward Power-Flo LX Pump; Hayward EC65A DE Filter; AquaComfort XL ACT-750 Heat Pump;
    Hasa 8 gal Liquidator;
    TF-100 Test Kit w/Speedstir
    38,354
    Re: First Closing/Opening TFP Method
    I think you should circulate and then test ... what is the point of brushing if you are not filtering it out?
    Snow and rain would certainly dilute the CH and borates and CYA
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    I bushed prior to filtering to mix the water a bit to see what the condition of my water was after 7 months of sitting under a cover. No water from rain or snow infiltrated the cover as the water level was the same 2" below the inlet.
    38,354
    So were the Nov. numbers before you partially drained the pool?
    If so, then of course the CH, borates, and CYA would be reduced from the tap water.
    cvgnus's Avatar
    May 2015
    Massapequa, NY
    46
    Yes the November numbers were just before I lowered the water to below the inlet. May numbers were _before_ I added water to the pool. There was no water of any kind added to the pool between November closing numbers and May opening numbers. If I did add 12" to 16" inches of water it could not explain the CYA of 0. Sorry if I was not clear in my posts
    Aug 2014
    Northern IL
    4,615
    Always best to circulate for a couple of hours before testing and adjusting.
