Thread: Need Pump Recommendation
    The housing near the drain plug on my Waterway SVL5 Pump is chipped and leaking water. I temporarily fixed with with teflon tape. A few years ago I replaced the motor with a 2 speed A.O. Smith B983 high efficiency. I am very happy with the way it performs.
    So I need a recommendation on a new pump. I guess the pumps comes with a new motor. I don't mind switching the motor on the new pump (to use my existing motor) when I buy it or even buying a pump with a new high efficiency 2 speed motor.
    Thanks in advance
    16,000 Plaster/Gunite - Pentair FNS Plus Fiberglass D.E. Filter
    Heat Siphon Heat Pump Z375HP- Hayward Pro Logic PL-P4 Automation
    Hayward Chlorinator Cell T-CELL-9 - Waterway SVL5 Pump
    A.O. Smith Two Speed Motor B983 - Solar Blanket - Polaris 380
    Test Kit K-2006c
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
