Thread: Pool liner popped off in a spot. J-Hook. How to I fix?
    Apr 2015
    Waterford, MI
    133
    I notice last year closing the pool my liner was popped off. Now its time to open and I want to fix it. I figure I have to drain nearly the whole pool to fix but wanted to show you guys and get all the advice I can. Thank you!
    Edit: Today and tomorrow its only 68 degrees if that make much of a difference.
    Michigan - 24'x54" AG, approx 15,000g, 2 center drains, Cartridge filter, Aqua Pro 2hp, 2 speed pump 3.5a@1725w / 10.5a@3450w, AquaCal TropiCal T90 heat pump, Hayward Salt & Swim SWG, Poolskim, Aquabot Rover Jr.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: Pool liner popped off in a spot. J-Hook. How to I fix?
    I'd wait for an at least 85 degree day, lower the water a foot, and put a heat gun or heavy hair dryer to it.
    Apr 2015
    Waterford, MI
    133
    I drained almost another foot out of it and used a hair dryer to heat it up. It didn't take much heat and it pulled up super easy. I did use a type of pliers called linesmens to get a good grip without hurting it. Wifey helped by operating the hair dryer.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,658
    Sweet! Nice to hear!
    Kim
    Casey's Avatar
    SW PA
    10,461
    I'd use a hair dryer over a heat gun. You can also use very hot water too.
