Thread: Just filled pool, green tinted water
    So, I'm guessing metals from the tap? Iron, copper?
    The water is crystal clear, it's just greenish. If it helps, we also just repainted the pool (epoxy).
    We don't have the pump or any chemicals in just yet, literally just filled it. Will the color clear up with filtration or do we need to use something to bring the metals out of suspension?
    Thanks!
    ~31,000 gallon rectangular gunite 16x32
    38 Sq. ft. DE Filter, TF100 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Just filled pool, green tinted water
    it really depends.. is this a well? have you had metals before..
    get the pump and filter going, get some chlorine in there and balance the water and see where you are in 48 hours...
    30,408
    Sounds like iron in the water from a well fill.....was that your source?
