Results 1 to 8 of 8
Thread: CYA Question
    Mar 2013
    CT
    348
    CYA Question
    My CYA is 45. So do I call it 40 or 50?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Jun 2014
    14,951
    Re: CYA Question
    I round numbers like my taxes ... 45-49 would be 50.
    Aug 2010
    Dallas, TX
    4,052
    Re: CYA Question
    Why not call it 45?
    Mar 2013
    CT
    348
    Re: CYA Question
    Im going by the cya/chlorine chat. There is no 45.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: CYA Question
    Always round CYA up to the next 10.
    Donldson's Avatar
    NW Ohio
    2,880
    Re: CYA Question
    Quote Originally Posted by pooldv View Post
    ^^This. The minimum numbers really are the lowest most people can maintain to avoid a problem. Meanwhile SLAM is a fairly conservative upper end. So there is really zero harm in rounding up your CYA number, but if you round down you could risk dropping too low. I suggest always rounding up the CYA number, even if it is nearly to the next line.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2013
    CT
    348
    Re: CYA Question
    Up it is. Or just add a bit more stabilizer to get to 50 i guess...
    Jun 2014
    14,951
    Re: CYA Question
    Yeah, plus with the CYA's +/- 15 ppm variance, we know CYA testing one of the trickiest, so I always find it best to err on the high side to ensure I have enough FC in the water.
