Thread: Should I use recirculate while putting DE in my sand filter?
    May 2014
    Burlington, NC
    45
    I am still trying to clear my murky green pool SLAMing since 5/11 and am to the stage where I am not seeing much change day to day. It is still cloudy sea green looking somewhat blue around the edges so I have started adding DE to the skimmer basket. I backwash after a few hours but am wondering if I use recirculate if that would be more helpful (after reading one of my questions from years past about what recirculate is used for.) I know from last year it will take a few weeks to clear but am trying to accelerate the process again. Is recirculate useful for this?
    FC = 15
    pH = 7.2
    CYA = 40
    Thanks for any input.
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    Aug 2010
    Dallas, TX
    4,052
    Re: Should I use recirculate while putting DE in my sand filter?
    Without DE, are you needing to backwash frequently?
    38,450
    If you are in recirculate mode when adding DE, the DE will not even get in your filter and will just be sprayed out into the pool.
    May 2014
    Burlington, NC
    45
    Oh okay thanks. That's definitely not what I want.
    No I have not needed to backwash as frequently without DE.
    Sta-Rite pump, 1HP?
    May 2016
    Clermont, Florida
    27
    Im not seeing test results. Do you test your own water? Specifically total alkalinity and calcium hardness.
    Last edited by BellissimoH2O; 05-20-2016 at 08:23 PM. Reason: Left out important detail
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Recirculate is good if your pool is really full of sludge and it clogs up the filter quickly and you can't be around to watch the pressure. Times like working and sleeping...
    If the water's still greenish, algae's still growing and no amount of filtering will clear it. You'll remove the dead stuff but what's still alive in the water will just grow some more.
    San filters actually filter best when they're a little dirty,. so backwashing more often than you must actually makes it filter worse. So watch the gauge. When it climbs 25%, then backwash. Concentrate more on maintaining FC levels and brushing. Algae will grow a slimy film - sort of a scab - to protect itself. You want to brush that off so it can be exposed and killed.
