Results 1 to 12 of 12
Thread: TA has not moved down much after lowering pH
    Sep 2014
    San Ramon, California
    65
    I've lowered the pH twice now from ~7.5 ppm to ~7.1 ppm but TA still hovers and registers ~110 ppm. Is there something else I can do to lower the TA?
    14,000 gals; IG gunite - Wet Edge Primera Stone finish; Sta-Rite/Pentair Intelliflo variable speed; Sta-Rite/Pentair system3 S7M400 cartrige; Sta-Rite Max-E-Therm 400 heater; (Pentair Rainbow 320 Chlorinator- for vacation use only); built-in automatic pool cover; Trident II UV system (on recall not currently used); built 10/31/2012; TFT-100; MX8 cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: TA has not moved down much after lowering pH
    Let it get up to higher, maybe 7.6-7.8, then shoot for 7.2. It may take a while to budge.
    Are you having pH swings? Is that why you are adjusting TA?
    30,413
    You really do not lower TA with acid alone. You must do it with acid/aeration. There is an article in Pool School that will walk you through the steps and your TA will stay down.
    Sep 2014
    65
    Quote Originally Posted by RobbieH View Post
    RobbieH - No, my pH hovers around 7.5 - 7.7 pH and only when it gets to 7.8 ppm in a couple to 3 weeks that I pull it down to ~7.5 ppm again.
    duraleigh - Yes, I lower down the pH from ~7.7/7.5 ppm to ~7.1/7.0 ppm then I make sure the return jets are pointed upwards to break the water surface for the rest of the day when the pump/circulation is on (I had done this scenario twice already). I also had the kids swim the other day (when we had 92degF in San Ramon) for ~ 3 hours to augment the pH rise.
    Aug 2010
    Dallas, TX
    4,052
    Will your pH stabilize at 7.8? Some do.
    Jun 2014
    15,056
    isabelo, if you are still struggling because the TA just doesn't seem to want to go lower than 110, then try dropping your pH to about 7.0. Just that extra "dip" in pH is what it took another reader for his TA to finally break that barrier where it was stuck at about 100. Once he lowered the pH to 7.0, the TA began to drop again, and of course the aeration raised the pH right back where it needed to be.
    Sep 2014
    65
    I've have not left it at 7.8 ppm long enough to see if it rises beyond that point. But usually, it goes from ~7.5 ppm to 7.8 ppm in a couple to three weeks, maybe even a month so I thought that is stable enough?
    Aug 2010
    Dallas, TX
    4,052
    That's up to you. That's a pretty long time compared to mine.
    Sep 2014
    65
    Quote Originally Posted by Texas Splash View Post
    I think I targeted pH to 7.0 ppm during my first try a week ago, then I lowered it to 7.1 ppm last Monday. But yes, I'll target for pH to 7.0 ppm again next Monday. We are expecting some rain (most probably drizzle if that) tomorrow, so that might help augment the pH rise in the weekend. Thanks.
    Thanks for the help, RobbieH!
    Sep 2014
    65
    Update - Just got my TA down to 80 ppm, it took about a two weeks process, but it worked. The trick is just what RobbieH suggested - get pH to as high as possible (7.8) then aim for lowering it down to 7.2 (or 7.0 in my case), then aerate (just like what Duraleigh said). The negative to this "acid/aerate" process is I had to consume a lot more Liquid Bleach, as you would understand - I have an automatic cover but had to open it up a lot for the aeration process to do it's thing. Thanks...
    Jun 2014
    15,056
    Glad you were able to make progress.
    Sep 2014
    65
    Thanks to you too, Texas Splash!!!
