- May 13, 2009
- 7
Hi Everyone,
I've found a lot of useful information here but I have some specific questions. I'm a first time pool owner after purchasing this home. Its a salt water set up. The house had been sitting vacant for a few months and the pool was green when I took ownership.
Present day the pool was drained, acid washed, refilled. The cell cord has been replaced, some grids in the filter have been replaced, all skimmers cleaned, cell and tri sensor cleaned. The cell is 18 months old.
Everything seems to be running normally right now. I just realized that the tri sensor had been installed backwards so the flow arrow was pointed in the wrong direction.
Actual question: How should I program the pool pilot and pump. The pump is currenlty programed to "external timer" so I am assuming it is controlled by the control panel in the house. The maintenance menu has options for program pump 1 and program pump 2. I am currently running the pool pilot unit from 10am to 5pm everyday. How should I set this up to maximize chlorine production?
Thanks for your help in advance,
Carlos
Carlos
