Thread: Need help with saltwater pool plumming
    May 2016
    Chilhowie
    1
    Why is there a ground going into the plumming ?
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Need help with saltwater pool plumming
    Welcome to TFP
    We are going to need some more info,
    what type of SWG?
    plumbing or wiring?
    pictures are worth 1000 words
    Aug 2010
    Dallas, TX
    4,052
    I hope someone isn't using PVC for grounding. Now my copper lines on the other hand...
