Thread: New owner of older pool, possible broken laterals. Need Help/suggestions
    ry428's Avatar
    May 2016
    Syracuse, NY
    2
    Hello everyone,
    My family and I recently bought a new house and it came with a pool. I am new to owning an IG pool. I am in the process of getting the water balanced and clear after opening it. I have vacuumed the pool and have notice more new dirt/ sand accumulating in the pool. 99% positive it is sand. My thoughts are that I have a broken lateral in the sand filter. I have a 36,00 gallon 20x40 IG pool. I am running a 1 1/2hp hayward super pump and it has a hayward sand filter. The pool was built in 1998 and we live in the Syracuse area of NY State. So here are my questions.
    -Are my thoughts correct with the broken lateral? or is there another possible issue?
    -Should I pull filter apart and replace sand and inspect/fix laterals?
    OR since I have an issue with the filter and will have to fix it anyway, do I upgrade to a DE filter? I have been thinking this because my research shows that DE filters filter better than sand. Is this true and would I be wasting my money upgrading to a DE filter (does DE really do that much better of a job)?
    Thanks
    Ryan
    IG vinyl, 20'x40'-36,000 gallons, Hayward sand filter & Hayward 1 1/2 hp super pump, municipal water when topping off.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: New owner of older pool, possible broken laterals. Need Help/suggestions
    You will be wasting money in either case unless you KNOW it is sand and the only possible source is your filter. Make sure it is sand first. Welcome.
    Aug 2010
    Dallas, TX
    4,052
    Turn off pump. Let it sit for 30 min or more. Have someone hold a sock in front of return. Turn on pump. After a few seconds see if you have sand in sock.
    I personally would not change to a DE filter even if someone gave it to me for free.
    ry428's Avatar
    May 2016
    Syracuse, NY
    2
    Thanks for the advice!
    30,426
    DE does filter finer than sand but they all have drawbacks and benefits. Unless you don't like your sand filter, fix it because it's what you are used to.
