Thread: Getting started for 2016 just want to clarify some things
    Jun 2015
    Lexington, NC
    123
    Just wanting to verify the order of some things I should be doing..
    I don't have exact numbers in front of me but I'm sitting somewhere around
    FC=10, CC was around .5 last I checked
    CYA <20 (filled to the brim of the beaker in the TFP kit I can still easily see the black dot, but it is "cloudy")
    TA around 20
    PH 6.8 (or less I guess)
    Haven't bothered testing CH yet.
    Thanks to the low CYA the FC can be maintained relatively low, and we've got a weather reprieve with cloudiness all week so not losing too much from sun.
    Right now I'm chlorinating with Trichlor shock from Wal-Mart to get the CYA up, however I know this also has the negative effect of lowering PH.
    IIRC from last year, it was best to get TA in the target zone before fiddling with PH. Last year I was apparently running a TA of around 50.
    Looks like I need to add about 13lb of baking soda to get the TA set, but also looks like the tri-chlor is going to pull the PH down faster than the baking soda brings it up. Should I be mitigating PH simultaneously, and if so, what's the best thing to use for PH Up?
    Also, my baking soda turned into a brick over the winter.. can I safely toss the brick into a skimmer and let it self-disolve, or do I need to break it up and broadcast? Or just get a new bag of baking soda?
    Thanks!
    ~30kgal in-ground concrete
    Hayward S-240 300lb sand filter
    Hayward 1HP pump
    Jun 2014
    15,178
    Re: Getting started for 2016 just want to clarify some things
    A few things happening at once here. I would raise the pH immediately with either borax or soda ash, whichever you have available. That needs to be in the mid-7s right away. I would get a new box of baking soda. It's relatively cheap and needs to be broadcast spread across the deep end. Make sure to get the TA up to around 50-60 at least. CYA will increase but it might be slow if you rely on shock and stuff. Definitely get it up to 30 as a minimum and make sure to keep the FC at around 4 or so - never below 2. Hope that helps.
    Jun 2015
    Lexington, NC
    123
    Where does one buy Borax/Soda Ash? Last year all I did for PH was baking soda and had been told to not adjust PH until after TA was at a decent level..
    Kept my TA around 50 for the rest of the season and kept the PH pretty stable at 7.5.
    Was at a CYA of 40 or so last year, guess I replaced a fair amount of water over the fall/winter.
    Hayward 1HP pump
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,077
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2015
    Lexington, NC
    123
    Thanks I was looking for that earlier and couldn't find it for some reason!
    Hayward 1HP pump
