Results 1 to 9 of 9
Thread: Identify My Filter - Newbie
    May 2016
    Long Beach, CA
    9
    Can anyone identify the make and size of my filter? It is about 42" tall, not including the pressure gauge.
    I am brand to taking ownership of the care of my pool. I back washed the filter and then realized I did not know the size of the filter in order to determine how much DE to re-charge it with.
    16,550, Long Beach, Southern California, IG Pool & Spa, Plaster (painted over, peeling & cracking), DE Filter (size/make?), Hayward Pump (model?), 2 Wheel "The Pool Cleaner" Auto Cleaner
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Identify My Filter - Newbie
    IMHO, it looks like a Pentair FNS. Pentair FNS Plus DE Filter - Pool Supplies Superstore
    If there is no ID tag on it how about giving the diameter of the housing and the height ??
    Photo showing the filters intake and return would be helpful too.
    Solar Blanket, Well Water, Borax Added. 68
    May 2016
    Long Beach, CA
    9
    Thanks for responding. This is my first post. I am brand new to this.
    May 2016
    Long Beach, CA
    9
    I just realized you added a link. Thanks! That does look like the one. And, based on the vertical clearance listed in the brochure, it looks like a 24 SQ FT version.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I'm always more comfortable if someone else jumps in to agree or disagree but it seems there isn't anyone else giving their opinion.
    Did you end up using the info from the 24 Sq Ft filter to recharge yours ?? Working OK for you ??
    May 2016
    Long Beach, CA
    9
    Thanks Kiss4aFrog. Prior to my post, I had just winged it. Everything seems to be working ok. Since then, I purchased a DE scoop. Next time which will be soon, I am going to break it down. I understand from the pool store that twice the length of the grids inside will be the Sq Ft. In other words, the grids should be 12" if it is a 24. I am about to post a new thread because I just received my TF-100. Please jump in there because I need advice. Thanks Again!!!
    38,275
    That looks like the size of my 60 sqft Hayward DE filter, if it uses the curved grids. Definitely bigger than the 24 sqft. It is either the 48 or the 60, my guess is the latter.
    Although the manual says a height of 43" is the 36 sqft ... but is that height the entire filter? Just the part that holds water or the grid height????
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by Long Beach DG View Post
    By golly, for once the pool store is right! By happy coincidence, on this particular filter, that holds true! The exploded parts diagram confirms it. That's easy. All you need is a tape measure while it's apart.
    May 2016
    Long Beach, CA
    9
    jblizzle, that is the height of the whole thing, less the pressure gauge on top.
    Richard, thanks for the owners manual. That confirms it. If it is in fact an FNS.
