Thread: Replacement Liner Question
    May 2016
    platteville wisconsin
    2
    Hello and thank you for allowing me to join!
    I ordered a replacement liner for our intex ultra frame 16 x 48 pool which is a 2012 model. The liner I recieved has 3 precut holes but the old liner had only 2. There is little info that I can find but I am assuming the extra hole is for the intex skimmer. I have done some searching on installing the skimmer and cannot figure out how all three holes are used as it says to remove one of the strainers from the other 2 holes to hook up the skimmer. Also not sure if a skimmer will work with the pump on the 2012 model? Is there a way to just this extra hole? Thank you!
    Intex Ultra Frame 2012 model. 635T cartridge filter pump.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Replacement Liner Question
    Welcome to TFP
    There are 3 holes in the new liner, 1 is for the return side and the 2 lower ones are for the suction side. the 2 are there so you can't get stuck in the suction underwater.. You will need these to modify it to the new suctions and pump
    Amazon.com: Intex Pool Plunger Valve with Strainer Assembly: Toys Games
    Here is what some of us have done, also check out my install below
    Cutting Larger Intake Return holes in your Intex
    May 2016
    2
    Thank you so much for responding! OK, I now understand that 2 are for the suction (the 2 side by side and same height) and the one to the left (and higher) is for the return. But the old pump only has "hook ups" for one suction and one return. So what do I need to do to modify to make the old pump work with the 3 holes?
