Thread: Robot during SLAM?
    Scout101's Avatar
    Aug 2015
    North Kingstown, RI
    166
    Robot during SLAM?
    So, saw a warning on the robot saying not to put in with FC higher than some fairly low number (4 maybe?). Also have seen people saying during SLAM is fine. Thoughts on which way is right? Maytronics trying to overly cover themselves?
    And with my CYA at 60, I'm now slamming at 24. Too much, or is the warning nonsense? What say you?
    IG Vinyl, free-form 25' x 40', 25,000 gal., Hayward 1-1/2 hp Superpump, Hayward S310T 500lb. Sand filter, AquaLogic T-Cell 15 SWG and Automation, Hayward H300 Milivolt 300k btu NG heater, TF-100 Test Kit w/spinner
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Robot during SLAM?
    Keep in mind that because of the CYA/Chlorine relationship, the actual amount of free unbound hypochlorite in your pool is less than 1 ppm at your current levels.
    This is actually less harsh than a pool with 0 CYA and 2 ppm FC. If you were to constantly maintain 24 FC (60 ppm CYA) and run your robot, over time it would reduce the overall life span of the unit. If you're using it during the SLAM and removing promptly after the robot cycle has completed, I wouldn't be concerned. Rinsing the unit off after you remove it wouldn't hurt either.
    Isolated Spa - 345 Gallons
    Scout101's Avatar
    Aug 2015
    North Kingstown, RI
    166
    Sounds good, thanks. I definitely only leave it in during the wash cycle and even rinse it after, so trying to maintain the life of the unit as best as possible; these things aren't cheap!
    Sounds like I'm good as long as I'm keeping it in the range of a normal SLAM and don't wander off with chemicals
