Thread: dichlor and increased cya
    May 2016
    star city/arkansas
    8
    in the pool school section, it mentions that dichlor will raise cya quickly. how quickly? is there a chart somewhere that shows cya increase/ lb of dichlor?
    also i know that dichlor has copper in it, same question for copper increase/lb of dichlor??
    17,100ga AG, 19" SAND FILTER,1.5HP WATERWAY PUMP; PERMASALT SYSTEM(TURNED OFF)
    Aug 2014
    Northern IL
    4,615
    Re: dichlor and increased cya
    Go to PoolMath at the top of the page and then scroll to the bottom where it says effects of adding chemicals. It will tell you how much CYA will be raised by adding dichlor as well as its effect on pH. If you need help navigating PoolMath, let us know.
    Regular dichlor does not contain copper.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    For some strange reason I felt like doing some math.
    In 17,100 gallons 1lb of dichlor will raise FC 3.9 ppm and CYA 3.6 ppm. So, assuming your pool uses the midpoint of the 2-4 ppm average FC per day at the end of 30 days you CYA will be about 82 ppm higher than your started.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Not all dichlor contains copper, just certain products
    May 2016
    star city/arkansas
    8
    Thanks for the info. Found the area on the pool calc. Learning new things everyday.
