Results 1 to 17 of 17
Thread: *Updated with test results!* Filled 12' Intex Pool, now what?
    Apr 2016
    Florida
    29
    So my 12'x30" steel-framed Intex pool has been filled. Now, I'd like/need advice on how to treat it, please! What are the simplest, gentlest options? I bought the Natural Chemistry Start-Up kit on Amazon, but I don't *have* to use it. I just thought it would be a gentle option for my three little children. Any help is greatly appreciated!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Filled 12' Intex Pool, now what?
    Do you have any type of test kit all all? You'll need something to measure pH and chlorine, at least. A better kit might be overkill for a pool your size. If a chemical catastrophe strikes, it's not such a big deal to stick a siphon hose in and drain it and start over.
    You do need to get some chlorine in the water. That's a given. Every day. Even if you don't see green stuff, the chlorine is also a sanitizer to kill any bacteria or viruses. Since you haven't added a thing yet... your target FC is 3. I'll help you out: that's just one measuring cup of standard 8.25% laundry bleach. So you know for reference, at 90% filled, your pool is 1718 gallons.
    Next step, check the pH. Whether you need acid or soda ash or borax or nothing at all depends on the reading you get from the test kit.
    Third step, add some stabilizer. The quantities you need are so small that you could get by with just two 8 oz trichlor pucks in a floater. When they're melted away, that's it. Your CYA will be about 40. You probably won't need to add much bleach while they're dissolving, either, since they have chlorine in them. Some pool stores sell them individually, or you can beg a couple off a neighbor or flag down a pool service truck when you see one.
    Pretty easy, really. Have you seen Pool School - Guide for Seasonal/Temporary Pools ?
    Also, take a few minutes to read ABCs of Pool Water Chemistry
    Apr 2016
    Florida
    29
    Wow! Thanks! All pretty Greek to me, but I will definitely take a look at the links you provided! Seems relatively easy, though! I do have testing strips that measure PH and Chlorine, and two other components I can't recall right now. Thank you!
    Just to check, the standard pump that comes with a pool like that doesn't handle salt, correct? Is salt much better?
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by eanik View Post
    Test strip results are notoriously unreliable. To properly care for your pool and get accurate advice here, you need either the K2006 or TF100 test kit. Both are around the same price, most of us opt for the TF100 since it contains more reagent for the tests you'll use most.
    K2006: Amazon.com : TAYLOR TECHNOLOGIES INC K-2006 TEST KIT COMP CHLORINE FAS-DPD : Swimming Pool Liquid Test Kits : Patio, Lawn Garden
    TF100:TF100: TFTestkits.net
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Apr 2016
    Florida
    29
    Great info! I'll grab a kit. Thanks!
    Richard320's Avatar
    Jan 2010
    18,988
    A salt pool is a chlorine pool. Instead of them making the bleach at a factory and bottling it up and hauling it all over, you make it right there next to the pool. It's handy, no doubt. Once you get it dialed-in, you don't have to add chlorine at all. But I can't see your little pool using more than about a cup of bleach a day. One jug of bleach every couple weeks is pretty inexpensive. When you start talking gallons per day, then a SWG makes real economic sense!
    A K-2006 or TF100 is probably overkill. But any drop-type tester is world's better than test strips.
    Apr 2016
    Florida
    29
    Gotcha! Thank you!
    Apr 2016
    Florida
    29
    My husband went to a pool shop nearby and with a sample of water since we do not have a kit yet. This is the report. He came home with a jug of Liquid Chlorinating Product, a bag of Total Alkalinity Increaser and a bottle of Stabilizer/Conditioner Increaser.
    I noticed the gallons are way off. Hmph. I assume I would just add half the amount instructed then? I will be buying a kit soon.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Enter your volume and calculate the amount to add here: http://www.troublefreepool.com/calc.html
    Start with 1/2-3/4 of what it suggests for 30ppm stabilizer(CYA) until you get a kit. Also add a few cups of liquid chlorine a day until the test kit arrives (calculate to around 3ppm with pool math).
    I'd hold off on adjusting TA and pH until you can test yourself. The good news is now that you have stabilizer, there's no need to go to the pool store! See here:
    Apr 2016
    Florida
    29
    Re: *Updated with test results!* Filled 12' Intex Pool, now what?
    Thank you!!
    @Richard320 How about this one? It is sold at the same local pool store. Amazon.com : Poolmaster 22260 5-Way Test Kit with Case - Basic Collection : Swimming Pool Liquid Test Kits : Patio, Lawn Garden
    Richard320's Avatar
    Jan 2010
    18,988
    Thank you!!
    That test kit will be plenty for what you need. And for anyone else reading this, it's because of the size of her pool. See:Pool School - Guide for Seasonal/Temporary Pools People with larger pools need to invest in a more complete kit because replacing water is a lot more trouble when the pool is 10 or 20 times larger.
    By the way, eanik.... you've already been pool-stored. If those readings are right, your alkalinity was just fine where it was. No reason to raise it. But if it did need raising, plain baking soda from the grocery store is exactly the same chemical and is about 1/5 the cost. There's one waste of money.
    You don't need to "shock" the pool. What could have gotten in it so soon? Your kids bathe in the same water without it being overdosed with bleach. The pool is brand new, so there won't be any algae residual left from last year to kill. I stand by my original recommendation to add a cup of bleach as the startup dose. The liquid shock you bought is probably stronger than plain laundry bleach, even though it's the same chemical. You may need to reduce quantities accordingly. Fifteen minutes after adding, the kids can get in. If you follow the pool store recommendation, the FC will be over 15 FC, unbuffered by any stabilizer, and has the potential to bleach out that brand new liner and reduce swimsuit life to days, hence the caution to stay out.
    You also ended up with way more stabilizer than you need. A 12' X 30'' intex filled up to 90% holds 1718 gallons. To raise CYA from zero to 40 will only require 9 ounces by weight or 9.6 fluid ounces by volume That's 1 cups of the granules. How big is the canister? 4 pounds?
    Anyway... that kit will work. But you and your husband are going to have to decide 1) Who's tending the pool and
    2) Whose advice will you take?
    TFP and pool store advice don't mix.
    Apr 2016
    Florida
    29
    I much prefer TFP. My husband thought I randomly read a recommendation online, and opted to try the store. Miscommunication! We don't have a lot of money to play with for a pool. Blessed enough to have one. Thank you so much for your detailed reply! I can return the chlorinating bleach and alkanyzer (unless I should keep some on hand). So just Clorox bleach and baking soda from the grocery store will do? They only had one size of stabilizer, my husband said. :/ I will be tending to the pool, for sure.
    I should mention the pool had to be taken down to be re-leveled and obtained a little green algae waiting for that to be taken care of. I rinsed it out, mopped with a little bleach and rinsed again.
    Aug 2010
    Dallas, TX
    4,052
    Yeah, take the alkalinity adjuster back and get your money.
    Apr 2016
    Florida
    29
    Thank you!! After searching around here, I did the recommended method of adding the granulated stabilizer to a sock and put in in front of the return valve. Now, How long do I need to wait to add the liquid chlorination? Thanks!!
    Richard320's Avatar
    Jan 2010
    18,988
    You don't have to wait. Pour it in. A cup's worth. Less if the shock is stronger than 8.25%.
    Have you seen poolmath It will do the arithmetic for you.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    You do not even need Clorox. You can use store brand bleach so long as it is plain bleach. Make sure it lists the % on the bottle. If it does not it is not worth buying. Right now Walmart has pool shock for cheap.
    Kim
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    I was under the impression (from reading similar posts), that we still treat temporary pools like full sized pools. I also thought the smallest metal frame Intex was still ~5k gallons, but I see OP's is much smaller. No matter though...
    There's $25 test kits that include CYA test here and here.
    Test Kits:
    My Pool:
