Thread: Skimmer Box Cover Brown After Opening Pool
    Jul 2015
    L.I. New York
    6
    Just opened my pool this evening and upon removing the cover I noticed my skimmer box covers (2) are stained brown. In the pool the skimmer door seemed ok but the rectangular finish piece around it is stained as well. Water was below skimmer for the winter during closure. Pool water is nice and clear. There were a few leaves on the bottom but overall it looked pretty clean. Any ideas what could have caused this? How to remove? I don't have any test readings yet as the sun went down before I could do any. Will do them first thing in the morning. Any help would be appreciated.
    Thanks.
    Rob
    31,500 gal. Vinyl IG Free Form Pool Built August 2014 - Pentair FNS Plus Vertical Grid D.E. Filter, Pentair Intelliflo Variable Speed Pump, Water Fall Feature, Taylor 81329 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Skimmer Box Cover Brown After Opening Pool
    Brown could be iron or could be organic stains from rotting leaves or acorns or the like.
    Get a Vitamin C tablet and set it on one of the (damp) stains. In about two minutes, you'll have a white spot where it was sitting if it's metals. The next test if it isn't metals is to sit a trichlor puck on and see if it lifts the stain. If yes, it;s organic, and high chlorine and time will fade it. Do them in that order because the puvk may also lift metals and give yyou a false positive on organics.
    More here: Pool School - Metals in the Water and Metal Stains
    Jul 2015
    L.I. New York
    6
    Thanks Rich. Vitamin C tab did nothing. TriChlor puck is now in place. Will check in the morning to see if there is any color change.
    Rob
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    No, dont let it sit there that long. The risk of it bleaching your liner is too great. Just 10-15 minutes is enough tops!
