Results 1 to 10 of 10
Thread: Should I Need to add any chlorine to cold water?
    Apr 2015
    South Central PA
    297
    This is my second year with a pool. I'm still learning and trying to insure everything seems right. I set up a Stenner this season, and I'm adding about 7 oz of 8.25% bleach per day. This is about a .25FC loss per day. The solar cover is on full time, and the water temp is in the mid to upper 50's (it's been pretty cold for this time of year). With these temperatures, should I need to add any bleach at all? I ask because I hear people talking about FC lasting through the winter. At this rate of loss, I would be out of FC in about 1.5 months after the closing SLAM (I had 0 FC on opening with a mesh cover). If this seems right, it's fine, but if it seems off I'd start an algae search.
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
    Donldson's Avatar
    NW Ohio
    2,881
    Re: Should I Need to add any chlorine to cold water?
    Your solar cover is blocking some, but not all of the UV from the sun. So I would expect a very small FC loss similar to what you are noticing. Remember, the sun is just as powerful now as it is in mid-July (that is to say, same position overhead).
    If you are worried you can try an OCLT, but I really think you can chalk the loss up to solar breakdown.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Apr 2015
    South Central PA
    297
    Thanks...just wanted to see is it made sense. I wouldn't really be able to pick up that loss with the FAD/DPD, as that's in .5 FC increments...I guess if I really wanted to I could do a 20ml sample, but I'm not that concerned if it seems in line with what's expected....
    30,403
    I am not sure what the goal is. Your Stenner seems to be working fine.....why are you considering adding chlorine? I think I am misunderstanding part of your post.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Maybe you could do a CC test and if it's where it should be, under 0.5 you know everything is good and that 7oz is an accurate daily amount.
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2015
    South Central PA
    297
    As I mentioned, people go the entire winter and still end up with FC upon opening, due at least partially to cold water. I'm simply asking if I should even need to add the 7 oz that the Stenner is adding, or should my chlorine consumption be about zero with the cold water. No intention of adding FC in addition to the Stenner.
    Jul 2012
    Chicago, IL
    356
    With water in the 50s and a solar cover, your chlorine consumption could in fact be near zero and you may not need to add anything at all, so nothing unreasonable about the results you are seeing. Ultimately though, your test results will tell you what you need to add. Has your FC been holding steady or showing slight increases each day with the addition of 7 oz (about 0.2ppm for your pool)?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Apr 2015
    South Central PA
    297
    It's been holding steady....probably about 3 weeks of 7oz per day maintains it at 4ppm.
    Jul 2012
    Chicago, IL
    356
    Sounds like at the moment you are replacing roughly what you are consuming. Assuming your target is 4 (which implies a CYA of 30) I'd just keep on keeping on as is, knowing that as it warms, swimmers get in, and that cover spends more time off your consumption will increase.
    Apr 2015
    South Central PA
    297
    Thanks...sounds like I'm relatively on track with what should be expected.
