Results 1 to 11 of 11
Thread: Intex Sand Filter
    Jul 2015
    Aiken SC
    33
    Intex Sand Filter
    When I put up my Intex Sand Filter I noticed that the PSI was around 10 (in the green zone). I'm sure being new in using this I've gone over board with backwashing and etc.. Today I noticed that my PSI is now down to 6 PSI. In addition to this, where the outlet hose goes into a basket before it goes into the pump, (the place where you can let air out), before I start it, I always let all the air out before starting. It seems like within 5 mins the water level goes down (about 1/2 way) as if air is getting back in. All hose connections are tight, no leaks. Would it be my skimmer that is causing the air or what?
    Thanks For the Help
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Re: Intex Sand Filter
    About the back washing question, you don't want to backwash too often. Sand filters filter better when they're slightly dirty. The dirt that gets caught in the filter filters finer microns and so forth. Also, you said air was being sucked into your lines? Is your water level halfway up the skimmer mouth?
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Mar 2016
    Wantagh, NY
    31
    Anything getting blocked in your skimmer that would cause the pump to drain the leaf basket container?
    Sounds like not enough water can be pulled out of the skimmer.
    Jul 2015
    Aiken SC
    33
    Quote Originally Posted by Blake1989 View Post
    I also have a Intex skimmer (the one that hooks to the side of the pool). I figure once the pump was running, I could see suction going on. I see very little suction even tho things are going inside. What's funny is I have a dual outlet pool. When I put my hand over the other suction cup, I can see the water going in, but then within 1 min the basket in the pump shows that the water when from full to almost empty. Is this normal or what can I do?
    Quote Originally Posted by mikepier View Post
    There is nothing blocking the skimmer.
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    So your inlet. Is it the standard Intex pipe inlet? The standard pipe that connects to the side of the pool. So water is entering your pump, running through your filter, and there is barely any pressure entering the pool?
    TF100 Test Kit
    BBB ALL the way!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    If your pre-filter basket (that's what it's called) is filling up with air when the pump is running, then you have a suction side air leak somewhere. If you turn the pump off, you may see water leaking back out of it. This may help you find it. Chances are it's the clear lid on the pre-filter basket. You really have to torque those things down tight.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jul 2015
    Aiken SC
    33
    When I turn off the pump I do hear water coming from somewhere as I think it's coming down the hose from the sand filter. Tomorrow I will tight down the clear lid as far as I can. If that is not the problem, where should I look next for this leak?
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Jeff speaks the truth. A suction side leak will show no mercy when it comes to keeping your system primed! Check your suction side piping. If I'm not mistaken, Intex uses hose clamps to tighten. Or you may have the screw type. Check all joints for leakage. Ensure there are no pin holes in your piping. Ensure Pump basket O-ring is properly lubricated with non corrosive lube.
    Visually inspect o-ring on pump basket for defects. Any slits or malformities will spell problems with proper sealing.
    TF100 Test Kit
    BBB ALL the way!
    Jul 2015
    Aiken SC
    33
    I just started to use a sand filter, and have no proof that he is.
    I just when outside and turned off my pump. Before I started it, I made sure that the water level was up to the top of the clear lid. When I turned off the pump, I noticed that the water level was half on the prefilled basket. I heard some noise coming from the other side, but no water was filling back into the basket. I then screwed off the clear top, and screwed it back on just as tight as I could. I then unscrewed the small top (that is on the prefilled basket) to let the air out) and the water came up to the top again.
    Tomorrow I will follow these steps. I will tight down all screws including lids. After this I will turn on the pump, wait an hour, turn it off and see. If it still leaks air, where should I look next.
    Thanks fellows.
    Mar 2016
    Crawfordville Florida
    11
    I had a similar problem... Even though the Intex fittings had the rubber L gaskets on the hose ends, I still had to wrap the threads with Teflon tape to stop the leak. With both the threads and nut being plastic, I couldn't get them tight enough without stripping the threads. Haven't had a problem with it since then. Pretty cheap thing to try as well.
    jmcdtucson's Avatar
    Jun 2014
    317
    There should be zero air in that pre-filter basket. None at all, not even bubbles. Any air means suction side leak. If run with that pre-filter basket half full of air you will likely burn out your pump so it's critical to fix it.
    My main suction side leak was due to the vacuum release valve on the outlet. It's the doo-hicky sticking up from the top of the outlet valve on the pool wall. Google it.
    Try covering that with your hand. If you do so with your hands wet, sometimes you can feel the air sucking past your hand. Intex gives you adapters to replace these if they turn out to be the problem. You don't really need them once you have a skimmer since a blockage would just cause air to be sucked through the skimmer instead thus releaving the vacuum issue.
    If that's not it, or if there are more leaks, tighten everything from the pool to the pre-filter basket. On the pre-filter basket, tighten the clear lid, the air release valve at the center of the clear lid, and the sediment release valve near the bottom of the pre-filter basket.
    Good luck. Suction side air leaks are a pain but they can be fixed.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
