Thread: New SWG pool
    May 2016
    Phoenix, AZ
    171
    New SWG pool
    I just got the keys to my new house and it has a SWG pool ~20Kgal (Haven't measured yet). The owner paid to replace the broken Polaris SWG with a new SGS Breeze 420 and I noticed they had it on BOOST so FC was high. Lowered the cell % to help lower it. Before replacing it their pool service was using pucks in a floater.
    Readings (with new TF100)
    Salt: 2800 (Taylor)
    FC: 14
    CC: 0
    pH: 8.2
    CH: 750
    TA: 400+ (got tired of drops)
    CYA: ~200 (Had to do half pool/tap and was almost right at 100 line)
    Since we won't move immediately and salt is low, I might just get it drained 2/3 and refill.
    Had a devil of a time with the TA drops.
    38,508
    Re: New SWG pool
    Welcome to TFP!!!
    It does look like the first step needs to be about a 60% water replacement to get that CYA reasonable. That should also lower your high CH some.
    Then circulate for at least an hour and retest everything.
    For the TA, did it seem like the drops were small and jumping out of the bottle? If so, you need to wipe the tip between drops as the instructions suggest. That reagent can have built up static in it when it is very fresh.
    May 2016
    Phoenix, AZ
    171
    Re: New SWG pool
    I took some water to a pool place just as a double check since it is the first time I used the test kit.
    Salt: 2900
    FC: 7.7
    CC: .15
    pH: 8.3
    CH: 905
    TA: 150
    CYA 127
    Phosphate: 400 ppb
    Iron: .3 ppm
    38,508
    Re: New SWG pool
    We don't trust pool store testing ... so no need to use gas and time to have them test it
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: New SWG pool
    Welcome to TFP and congrats on the new pool!
    Trust your test results, we do. Except your TA, we want you yo try that again. Hold the bottle vertically, let the drop form fully, wipe the tip on a wet towel or swimsuit and swirl between drops. If you can rub your belly and pat your head you are good to go. Drop with one hand and swirl continuously with the other.
