Thread: please help
    May 2016
    BArrie
    1
    please help
    pool is aprox 12500 gallons liner pool brand new.
    PH 7.5
    alk 100
    hardness 175
    CA 10
    0 phosphates
    water is clear
    question below
    I had 1 ppm chlorine running a chlorine puck feeder for now tell i get up to aprox 30 CYA.
    when I had my water checked it had .2 CC and i was told to shock it last night with HTH extra shock 454 grams
    left the pool cover off and today when I had my water checked it had 5 ppm free chlorine and 1.2 CC
    should my shock not killed off the .2 cc
    the pool store told me to just leave it for now
    thanks everyone
    Jun 2014
    15,189
    Re: please help
    Sorry, I couldn't resist. But you know, here at TFP we strongly encourage pool owners taking 100% control of their pool by testing their own water with a TF-100 or Taylor K-2006. It's the only way to guarantee 100% ownership. It's fast, easy, and you won't waste time on "shocks" and products that drain your pocketbook. Right now you have an imbalance of FC and CYA which can inevitably lead to algae. The right test kit will resolve that problem. Please see the TF-100 link below in my sig. Great to have you with us.
    Aug 2014
    Northern IL
    4,615
    Re: please help
    And no more driving to the pool store! Yay!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: please help
    Is CA supposed to be CYA 10? If you have been chlorinating with pucks and shocking with dichlor it is very unlikely that CYA is 10. Add your state to your location in your profile so it shows up over there <---- and we will be able to make a recommendation on CYA. Climate is very important.
