Results 1 to 12 of 12
Thread: Newbie needs Black Algae and SLAM help please!
    May 2016
    Forney, TX
    5
    I am in process of doing SLAM on pool due to Black Algae. My readings this morning with K 2006 FAS DDP:
    FC 12, CC 0, PH 7.6, TA 80, CH 130, CYA 50. Filters clean.
    My question(s):
    1) Should I add acid to lower PH more before continuing SLAM? (I added 30 oz yesterday when PH was 7.8, I also added 3 - 96oz 8.25% bleach)
    2) Should I also add baking soda in increase TA before continuing SLAM?
    3) Should I increase CH as well?
    I also received a decent rainfall last night, probably .5 to 1 inch.
    As a note, I have definitely made some progress on the Black Algae, not gone of course, but improving.
    16300 gallon, free-form, gunite, plaster
    Built 1989
    Pentair FNS Plus, 48
    Polaris 360 Pressure-side cleaner
    30,426
    Re: Newbie needs Black Algae and SLAM help please!
    I would say no to all three additions. I would simply focus on the black algae removal and make sure you get it.
    Once that big task is complete, then retest your CH and bring it up to 250 if you need to.
    pH and TA are just fine.
    How does your water look?
    May 2016
    Forney, TX
    5
    Water is clear. Black algae fading with brushing! I calculated FC SLAM level of 16. CYA tested at 40 when I started. Do you think I should take FC higher?
    Built 1989
    30,426
    Honestly, yes and no!
    SlAMming to get rid of black algae is quite a bit different than SLAMing to get rid or green or mustard. Black algae requires a constantly high dose of chlorine over a long period so you can continue to knock it out with lot's of brushing, more chlorine, lot's of brushing, more chlorine, etc.
    So the idea is longer term exposure and my bet is that it doesn't do enough good to raise your FC way up because of the cost.
    In short, I think what you are doing is perfect. I suggest you continue exactly as you have (especially the brushing) and simply see what develops.
    It's a good idea to take some pictures so you can see your improvement. You may get a little discouraged as the pace slows.
    May 2016
    Forney, TX
    5
    Thanks so much for the guidance! Yes, it's a slow go but I am already impressed with the progress. Pics are a great idea as it is difficult to really gauge the change. I lost 1 ppm over night so bleach, brush, bleach, brush, brush today! We are out of the rain forest mode for a few but that means more sunshine and heat to deal with!
    Built 1989
    Aug 2010
    Dallas, TX
    4,052
    Since you have a plaster pool, I have found that those stainless steel brushes make it a lot easier to get the black algae broken up, if you are having trouble getting it loose.
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,522
    Just out of curiosity, is the black algae forming in places where the plaster is cracked or outright damaged/missing?
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    May 2016
    Forney, TX
    5
    Quote Originally Posted by BattleOfYakima View Post
    Yes it is. Definitely need to re-plaster but not an option at this time. Also, from what I have read about Black algae, even,re-plastering may not end the problem!
    Built 1989
    Apr 2016
    Central Florida
    1,522
    Has it started to separate in sheets yet? with black algae forming behind it where the water doesn't circulate and the algae starts to dome the plaster inwards? that's my favorite. not.
    May 2016
    Forney, TX
    5
    Loosing the battle! Need advice please! I am making great progress with black algae on sides of pool but cannot get it in deep end on bottom of pool due to my inability to brush it well. Any thoughts on using Algi Ban? Will it blow up the CYA in pool?
    Built 1989
    Apr 2016
    Central Florida
    1,522
    Is a longer brush pole or an extension a possibility? Perhaps even just getting another pole and banding them together, perhaps even with duck tape or a sleeve around them, like metal banding or pvc pipe. I have to imagine an extension of some sort is a possibility. Wall whale brush? Metal brush with down force fin?
    If not, keep reading...if you wish and at your own risk.
    Disclaimer: This is not an expert opinion. Please await others to chime in.
    If the following are all true:
    1. The water is crystal clear, as in you can see the bottom of the deep end clearly when the water is still, see where the individual screws are on the bottom drain /or/ see the individual black algae dots
    2. You still pass the OCLT
    3. CC is 0.5 or lower
    4. your FC is just below the shock for your CYA
    5. ph is 7.2-7.6
    6. you are healthy or have a healthy volunteer (ie. perfect health, not immune-compromised, no allergies to mold, no infections, no diseases)
    7. you know the risks and/or have the volunteer sign a waiver
    8. the water is not so cold as to risk health issues
    then if it were me, I'd get in and brush it, being careful not to get water in my eyes/ears/mouth/nose and getting in and out as fast as possible, then showering immediately and thoroughly
    i'd retest and top off chlorine after my shower, then again later. and keep slamming until the black was gone. doing the in pool brush once per day. maybe twice. but never within 8 hours.
    this is all based on my own black algae fighting experience, i am not an expert, am not a scientist, am not giving advice, just saying what I would/have done.
    Apr 2016
    Central Florida
    1,522
    Just notices that TFTestKits also sells brushes with spoiler fins. Perhaps those plus a couple telepole extensions and you'll be in business.
    TFTestkits.net
    Also potentially available at local pool store/Amazon/other, but perhaps different models/quality/price.
    How is it going btw?
