Results 1 to 13 of 13
Thread: First reading with new test kit
    May 2016
    Lilburn (suburb of Atlanta) / Georgia
    8
    New pool owner. I had the liner changed and switch to SWCG in March. So it was an early opening. I have been taking a water sample to my local pool store, but then I found TFP and purchased a TF-100 and K1766. Today I made my first test and hopefully I did things correctly. It rained last night so I did not do the test until about 13:30 so the water would be mixed, the pump starts at 11:00 and stops at 20:00. The SWCG is set to 45% and the water is crystal clear. We have not been in the water yet because it has only been about 80 the days we could have gotten in. Water temp today at time of test was about 77.
    FC = 10
    CC = 0
    CH = 200
    TA = 80
    CYA = 40
    CL = 10+ It was a little darker than the top shade.
    pH = 8.2
    Salt = 3600
    I know to look at the charts and use poolmath, but does anybody see anything that is way off and if any need working on which should I work on first?
    Jack Allen
    18,000 IG 16X36 L Shape Vinyl, Sand Filter, SWCG Hayward Aquarite 900 T-15, 1 drain, 2 skimmers, 3 returns.
    Jun 2014
    15,008
    Re: First reading with new test kit
    Hello Jack! First thing to ask ... is the water clear with NO signs of algae? If so, then I would lower that pH down to about 7.5-7.6 first. Then, since you have a SWG, increase CYA to 70 with stabilizer. Your FC will slowly fall and can stay round the 4-6 range. That's it.
    Now if you suspect algae, then that's different and requires some level adjustments. Just let us know. Great job on your first TF-100 test Jack. You're a pro now.
    May 2016
    8
    Thanks for the quick reply.
    The water is crystal clear, no signs of algae.
    The pool store test has always recommended I increase CYA, it was 10 the first time I took the water sample in. I have been added conditioner each time after a test and it has increased each time. I did not want to put the full amount of conditioner they recommended because I did not want to over do it. I have 2 skimmers, so I am going to put a sock with conditioner in each today.
    Jack Allen
    Jun 2014
    15,008
    It's good you were cautious about the CYA until you could test on your own. Now that you are sure, you can increase as needed. Of course make sure to test CYA in that viewing tube outside under a bright sky with the sun at your back. Glad to see you managing things so well. Good job.
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    With your pump run time, you can also try dropping your SWG percentage after you get your CYA up a bit.
    If your FC stays higher than you want you either lower the run time hour or lower the %.
    May 2016
    8
    Updating my progress and correction on one of my readings from my first post.
    I did put a sock with conditioner in it in each skimmer last week and my CYA level is up some. May be a little bit better at testing now too.
    I had pressure washed the concrete around the pool last weekend and a little dirty water went into the pool. So the bottom of the pool had a little bit more black stuff when I vacuumed it yesterday before our first pool party. End of school for teachers. I increased the SWCG from 45P to 50P and let the pump run all night.
    Here are my current test done today at about 13:30.
    FC = 11
    CC = 0
    CH = 250
    TA = 90
    CYA = 60
    CL = 5+ (The tester has 2 columns and I used the wrong one on my first test)
    pH = 8.2
    I have purchased Polyquat 60, but I have not added any yet to lower the pH.
    I have put another sock with conditioner in 1 skimmer to raise the CYA.
    Jack Allen
    Jun 2014
    15,008
    Jack, you are doing great, and glad to see you are more comfortable with testing. First thing .. you do need to lower pH, but not with Polyquat. You simply want to use Muriatic acid. If you have any questions about the muriatic acid, please let us know. You're raising the CYA a little more for your SWG, so that's perfect. FC is a bit high, so you can back off a bit on the SWG to let the FC fall more around the 4-6 range. Other than that you are doing quite well.
    triptyx's Avatar
    Apr 2016
    1,438
    Hold off on the Polyquot - that's an algaecide and I'm not sure it will have any real effect on your Ph.
    To lower your Ph, you'll want to add muratic acid.
    Edit - Ninja'd by the great TexasSplash.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Welcome and glad you got the right test!
    You really need to get your PH down ASAP. 8.2 is the test limit and your PH could be higher. Your SWG will also increase PH, so you really need to stay on top of your PH. You can get Muratic Acid at Home Depot, Lowes, ACE. Make sure you check the baume. The 31.45% is the highest concentration and is usually the most economical. Be careful not smell the fumes and don't place it anywhere near metal or bleach.
    Using the powder test for FC is sufficient. No reason to test FC (CL) using the 2 column tester.
    Save the polyquat 60 if you close for the winter. It doesn't get rid of algae and is a preventer. If you don't close for the winter, try to return it.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jul 2014
    Hope Mills, NC
    567
    You need to turn the SWCG DOWN, not up. I have mine at 30%.
    Also, don't worry about the pH until the FC gets down a point or two, as high chlorine messes with the pH test.
    Other than that, everything looks spot on!
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    May 2016
    8
    I have another thread about semi closing my for 3 week while we are on vacation and it was recommended I add some Polyquot before putting the Safety Cover on. I will have to get some Muriatic acid to lower the pH. I will do some searching on it. I am sure I will find that I can it at a Home Improvement store if I remember correctly from what I have read. But if somebody wants to provide some quick information that would be appreciated.
    Jack Allen
    Jan 2012
    7,264
    Lowes, in the paint department. 30% 20 Baum. Probably about $8
    Jun 2014
    15,008
    Here you go Jack. A couple examples:
    Muriatic Acid (Home Depot):
    Muriatic Acid (Lowes):
    Muriatic acid is also one thing we don't mind terribly if you get it at the pool store (usually 2 per case). Just grab it and leave before they try to sell you any snake oil.
