Thread: CYA Accuracy
    Jul 2014
    Charlotte, nc
    25
    CYA Accuracy
    Using a TF-100 my CYA reads zero. (I can see the black dot when filled completely.)
    But I know it is not zero. I had the local pool company test it twice 2 weeks apart and they have a reading of 30 ppm both times.
    Also my SLAM calculations are jiving at 12 ppm shock level when I add/test; so I am inclined to think pool store is correct.
    I am certain I am following the instructions correctly.
    Could the R-0013 Reagent go bad?
    Does anyone have experience with inaccurate CYA testing using the TF-100?
    FC: 5
    CC: 1
    PH: 7.0
    TA: 80
    CH:100
    CYA: ?
    22,000 vinyl IG 18x36
    Hayward Star Clear II cartridge filter; 100 sq ft
    Pentair 320 chlorinator 3" Tabs
    Pentair 1 HP motor
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: CYA Accuracy
    In general, pool store testing for CYA is some of the worst. How did they test? Using the Taylor turbidity test or a whiz bang computer system?
    Your CYA is likely not zero but less than 20 if it's clear to the top of the viewing tube.
    Isolated Spa - 345 Gallons
    Jul 2014
    Charlotte, nc
    25
    Re: CYA Accuracy
    They are using Taylor test products for sure. And your point is noted: But I am 5 days into the SLAM and while it is premature for an OCLT test, my overnight loss is sometimes around 1ppm; and sometimes during sunny days it is less than 2ppm; wouldn't a CYA of 20 be unstable and cause massive loss of FC...especially when at shock levels of 12-14?
    Pentair 1 HP motor
    Aug 2010
    Dallas, TX
    4,052
    Re: CYA Accuracy
    Test to be observed on sunny day with back to the sun. I seriously doubt the pool store is going outside to test.
    30,432
    Re: CYA Accuracy
    PM me with your name and # and I'll call and help get you fixed up.
    Dave
