Thread: Hoses from the pool cleaner jolt when the pump activates
    May 2011
    Miami, FL
    271
    Whenever I turn the pump on or off, the hoses of my pool cleaner whip in a violent jolt, and suction quickly begins.
    What might cause that to happen? An air leak somewhere? An air leak in my pump's strainer basket from not sealing properly?
    16,900 gallon inground pool (16x30 with spa bench)
    Sta-rite cartridge filter
    Diamondbrite surface, redone in 2017.
    1.5hp Hayward Super Pump
    Hayward Navigator Pro suction cleaner with V-flex kit
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Hoses from the pool cleaner jolt when the pump activates
    What other openings are there for the water to feed the pump? If the cleaner is the only source of water, then the hoses are straining under the stress of the pump starting and trying to feed it water. It is similar to covering up the end of your carpet vacuum hose and watching it shrink/move.
    If possible, you can make sure the skimmer and main drains valves are fully open when you start your pump. Then slowly close them off to start vacuuming. Maybe that will help.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    May 2011
    Miami, FL
    271
    I have 1 main and the skimmer.
    So, this is a normal behavior then?
    I'll try your suggestions to investigate, but I can't be doing that every time I turn the pump on.
    Pool Tool's Avatar
    May 2014
    757
    Normal could be a stretch, but you have a large pump and if it is trying to suck all it's water through the hose it may lurch. I don't think it is air in the line since it also happens when you turn it off when there would be zero air in the line.
    May 2011
    Miami, FL
    271
    good points...Thank you
