Results 1 to 11 of 11
Thread: Aqua Genie Loud Gurgling
    May 2016
    OTTAWA, Canada
    8
    Still Trouble shooting my pool after opening. My Aqua Genie Skimmer seems to be generating a lot of waves and bubbling and attendant noise around the return. It's slightly above the fill mark and I can hear the noise through a closed door. If I just push the inlet weir down slightly it calms down. Is there some adjustment one can make on the weir flap?
    38,262
    Re: Aqua Genie Loud Gurgling
    Picture? Seems like maybe the water level needs to be a little higher?
    May 2016
    OTTAWA, Canada
    8
    The water level is high - about 1" above the recommended mark; With it much lower the noise is indeed much worse with bubbling wave action 2 or 3 feet out into the pool. The wave action is now about 6" to a foot out into pool.IMG_20160520_1308541.jpg
    38,262
    I just became aware that these skimmer/returns existed last week, so I have no idea how they are supposed to work or if the noise is normal.
    See anything interesting look down into it from above?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I have the Aqua Genie also. Sounds like it's the weir...possibly stuck upward position? Mine doesn't work to good. Stays open most of the time. I couldn't begin to tell you what to do but hopefully someone else will come along shortly.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    Aug 2014
    Albany ny
    65
    Check to see if the return plate is mounted upside down. the return plate should shoot the water down. Just guessing that whoever winterized reinstalled it upside down, shooting the water towards the surface. For what it's worth I've got two Aqua genies and might be in the minority but for my pool there fantastic and would use them again in a heart beat. I do not use the chlorine feeder option though, tfp all the way!
    Kris
    14x26 rectangle vinyl liner pool . 1.5 hp 2 speed tri star pump, 2 aqua genie skimmers , no main drain. 175 sq ft star clear cartridge filter. 200,000 btu hayward heater Tf-100
    May 2016
    OTTAWA, Canada
    8
    After finally getting in my pool yesterday for the 1st time this season I was able to get a better look from down low in the pool at my Aqua genie problem. It looks like close to half of the return water from the pressure chamber is escaping upwards from the faceplate directly back into the inlet to the weir/flapper. I think my winterizer closer/opener has messed things up - either the gasket is defective or installed improperly. Holiday weekend finishing here but I'll get to my pool servicer tomorrow. This is obviously the cause of the loud gurgling and probably my startup higher pressure than normal. In the meantime any comments would be appreciated.
    Aug 2014
    Albany ny
    65
    I wouldn't call anyone... Just take out the six screws and install the plate so it shots the water down. Phillips screwdriver, #3 preferably. After all , the heart of tfp is self reliance.
    Kris
    May 2016
    OTTAWA, Canada
    8
    But it is shooting ~60% of the water down through the orifice slot. The water going straight up seems to be a leak around the faceplate/gasket.
    Aug 2014
    Albany ny
    65
    Got it now ..... Maybe he forgot to put the gasket back.... Or lost it, I have a couple extra , I didn't like how thick they were so I made thinner ones. I could send you one if you need it or you can make one.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have an aqua genie also. Either the gasket was left out, or the plate is on upside down.
    Divin Dave,
