Thread: Pump Strainer Lids Sun Beaten - No Longer Clear
    Jul 2013
    Phoenix, AZ
    67
    Hello Guys, the lids on my two pumps and leaf vac used to be clear so you could see if there was water moving. Now after years in the Arizona sun, they are all foggy. Is there a way to restore these, or would I need to replace. Thanks!
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    430
    Re: Pump Strainer Lids Sun Beaten - No Longer Clear
    uh, might try that auto headlight restorer stuff.
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    Pretty sure they're polycarbonate so the headlight restorer should work. Otherwise around $20-$30 to replace (with O ring).
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
