Results 1 to 14 of 14
Thread: Algaecides, Clarifiers, and Tablets
    May 2016
    Brandon, MS
    34
    After reading some of the threads and reviewing pool school, I now do not trust anything the pool store told me, which is probably a good thing.
    The pool store has told me proper maintenance needs Cal Hypo weekly, along with daily tablets, weekly algaecide, and weekly clarifier. If I maintain FC using bleach by adding daily, am I understanding correctly that I do not need tablets and algaecide?
    What about clarifier?
    Thanks! The more I learn the less I know...
    Greg - Mississippi
    18' x 36'* 23,000 gallons * Vinyl * Manual Chlorination * Pentair Sand Filter * Pentair Variable Speed Pump * Polaris 360 * TF-100 Test Kit
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Algaecides, Clarifiers, and Tablets
    You've got it. Check out this article Pool School - Recommended Pool Chemicals
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    I use nothing except for bleach (liquid chlorine) and muriatic acid 95% percent of the time.
    CalHypo - raises calcium; only way to eliminate too much calcium is water replacement
    Tablets - Trichlor & Dichlor; both raise CYA; only way to eliminate too much CYA is water replacement
    Algaecide - Polyquat 60 is used during pool closing in cold climates but seldom recommended otherwise. Some (most) algaecides contain copper, which can lead to staining and turning hair green. Only way to eliminate copper is water replacement
    Clarifiers - very seldom if ever recommended as they simply aren't needed in a properly maintained pool with accurate testing and timely dosing.
    Bleach (liquid chlorine) - does raise salt levels, but not normally to levels noticeable by us.
    The debate is on-going whether the Pool store will tell you these things to raise profits or simply because that's what they have always done. Either way, it is bad logic.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    I saw the title and the first thing that came to mind was "Oh my!"
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    May 2016
    Brandon, MS
    34
    Great! Saves me some money!
    Uh oh though. I just bought 100 lbs of Cal Hypo last week...can I use this up before switching to bleach or is the calcium increase too big of a problem?
    Greg - Mississippi
    Pool Tool's Avatar
    May 2014
    757
    Just follow the road to the pool store, wait!!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Quote Originally Posted by southernpool1 View Post
    What is your current CH? Use the calculator at the bottom to determine what adding x of y will do to your water http://www.troublefreepool.com/calc.html
    Pool Tool's Avatar
    May 2014
    757
    You have a vinyl liner, so CH levels are not really a factor for you. It does affect the CSI (see it in poolmath) but that can be managed, although 100# is a lot. I am guessing your pool volume is similar to mine, @ 48% Calhypo that would raise CH almost 200 ppm. Not terrible, but not ideal.
    Use PoolMath, effect of adding chemicals, to see the effects. http://www.troublefreepool.com/calc.html
    May 2016
    Brandon, MS
    34
    73% Cal Hypo...will check CH when I get home.
    Greg - Mississippi
    Pool Tool's Avatar
    May 2014
    757
    That's about an additional 300 ppm then neglecting splash out and rain drains. CH will not evaporate off though.
    May 2016
    Brandon, MS
    34
    150 ch
    Greg - Mississippi
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    450 is a tad on the high side and will make it a lot more important for you to watch your PH to avoid scaling. I wouldn't take CH above 300, 350 max.
    More here, Pool School - Calcium Scaling
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Well, I think you mis-understood them. All these things are required for the proper maintenance of the owners cash flow and boat payment. It has nothing to do with your pool.
    Support the site
    May 2016
    Brandon, MS
    34
    Quote Originally Posted by tim5055 View Post
    Tim, I think you're right!
    Greg - Mississippi
