Thread: Filter sizing?
    Chisek's Avatar
    Apr 2016
    Homer Glen, IL
    13
    Filter sizing?
    I have a Hayward 1.5hp super pump. I also have a Pentair CCP 420 filter assembly & I have a Hayward C3025 filter assembly. Which filter assembly would be better to run with my pump? I am new to the pool game. I thought bigger is better but am being told that the Hayward is closer to the GPM in turn being the better option of the 2. Thanks in advance for your help.
    If it matters my pool is 18'x40' 3.5' deep in the shallow & 8.5' in the deep end. It's also a concrete pool & the pump is 5' from the pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Filter sizing?
    Bigger is always better for filters. GPM rating for a filter doesn't mean much as long as you don't exceed it.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Filter sizing?
    Bigger will allow you to go longer between cleanings.
    Solar Blanket, Well Water, Borax Added. 68
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Filter sizing?
    The 420 is the winner here 100 sq ft bigger than the Hayward..
