Thread: New to AG pool in TX....
    May 2016
    Texas
    21
    Howdy all, I am new here and new to above ground pools. We had a huge homemade inground pool since for 30 years that was easy to take care of compared to this above ground. Totally different environments.
    I too have given up on the pool store water testing. Always different results and then the recommendation to buy something else to dump in to fix the issue. When you finally discover root cause, you wonder if they sold you all those chemicals intentionally knowing they wouldn't work. I don't think that is the case but still very aggravating.
    Quick info on current pool condition..let it go throughtout the winter due to it getting filled with leaves from all the huge oak trees which have since been trimmed to hopefully mitigate that issue...drained and refilled twice due to first time shocked using granular dichlor and raised cya to crazy levels but that was before I found this place.
    I think I am on the right track. Testing chlorine daily
    PH was 7.4 yesterday
    CC was 2 which is odd because it was 1 the day before?
    FC 11 was 12 day before
    TA showed to be 150
    I have since determined I shouldn't be testing anything but FC and CC at this point, correct?
    Also, water is cloudy but clearing up slowly, backwashing about every two to three days.
    Thanks folks for all the wonderful info you have here.
    Bill
    13000 AG (above ground) 24 ft round
    Carefree High Rate Sand Filter 19 inch, 150 lb capacity
    Waterway Hi-Flo Two Speed Pump Model No SD-10-2N11MB
    June 2014 / Taylor K-2006 / City Water
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: New to AG pool in TX....
    Are you currently in the SLAM process?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Welcome to TFP!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to TFP moondogtn
    Solar Blanket, Well Water, Borax Added. 68
    May 2016
    Texas
    21
    Quote Originally Posted by woodyp View Post
    Thanks for the welcome. I am currently in the SLAM process. If I am understanding this correctly, I need to maintain a Chlorine level of 12 since my CYA was between 20 and 30 the other day. This is what I am attempting to do at this point. I live just south of San Antonio and we have had quite a bit of rain which I am enjoying for the yard but not digging for the pool.
    Casey's Avatar
    SW PA
    10,448
    Welcome!
