Results 1 to 8 of 8
Thread: CYA Test Question
    Mar 2013
    CT
    348
    CYA Test Question
    Does the water need to be at room temp to accurately test CYA?
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: CYA Test Question
    That seems to be the current consensus.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    It seems that the stuff doesn't react and get cloudy very well below about 70F and will give a falsely low reading. If your water's cold, just set a cupful of pool water in a sunny windowsill a while to warm up and use that to test CYA. Don't test the rest with the sample that's been sitting, just CYA. Do the others straight from the pool.
    Mar 2013
    CT
    348
    Perfect. Thanks.. I added some conditioner last week after testing the water when it was very cold.. Hopefully I didn't overshoot...
    Aug 2014
    East Northport, NY
    155
    So would cooler water give a lower result?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Quote Originally Posted by Amanda14 View Post
    Yes.
    Aug 2014
    East Northport, NY
    155
    I didn't know that. Interesting, thanks
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Good to know. Hadn't run across that information before.
    Solar Blanket, Well Water, Borax Added. 68
