Thread: leaf trap leaking water when pump is turned off
    May 2016
    Goose Creek
    2
    When our pump is in sleep mode and the hoses are open (unlocked), the leaf trap has water leaking out of it. What would cause this to happen?
    Jun 2014
    15,178
    Re: leaf trap leaking water when pump is turned off
    Hello Tfowler! There are so many type of leaf traps on the market, it would be nice to see a pic if you can upload one. Also, just to make sure ..... by any chance you aren't referring to the pump's strainer basket are you? Generally when water squirts or leaks out when the pump is off it's a sign the rubber O-ring gasket is bad or missing.
