- Aug 23, 2012
- 37
Add the CYA and also raise the TA to about 70. The normal pH rise and the extra aeration should counterract the minor pH shift the CYA will make. And if not, then you raise it with borax once the CYA is all dissolved and you see where pH ends up.
Can I add CYA and increase TA at same time? I assume a half hour after I put in my sock CYA to slowly dissolve, I can start working on increasing TA at the same time?
