Results 1 to 8 of 8
Thread: Installing a Jandy Natural Gas heater in a garage....
    Apr 2012
    Lynchburg, VA
    90
    Curious,
    Why is it necessary to elevate the heater 18" if it is enclosed in a garage?
    TIA
    PF
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Installing a Jandy Natural Gas heater in a garage....
    Quote Originally Posted by Pool_Fool View Post
    Curious,
    TIA
    PF
    In the event of a flammable fumes (Think leaking gas can or paint thinner), the ignitor/pilot will be above the pooled fuel and the house hopefully won't go up with a bang. Your household water heater is probably sitting on a platform for the same reason.
    Jan 2016
    TX
    157
    Curious,
    TIA
    PF
    Make sure you have proper ventilation and carbon monoxide detectors in the house/garage
    Gunite Pool/Spa, CLI Caribbean blue crystal stone smooth, Pentair 3hp Intellifo VS, Pentair Quad DE Filter, Pentair 400k BTU Heater, KK Prowler 820, Pentair PSL4 controler with Screenlogic wifi, Inline Chlorinator, Pentair 1.5hp Spa Blower, TF-100 Test Kit w/ Speed Stir. My 2016 Pool Build
    Because it is a potential ignition source for gasoline or other flammable liquids or vapors that could potentially be near the ground.
    Support the site
    Apr 2012
    Lynchburg, VA
    90
    There is a 12" inch hole directly above it for air to come in(old vent hole from an old heater), and we are thinking of venting it horizontally directly through the outer wall.
    Does that sound like a decent amount of air flow?
    Richard320's Avatar
    Jan 2010
    18,967
    The heater manual and the local building code get the final say on that.
    Jun 2012
    western NY
    1,559
    Richard nailed it. Ignition sources in basements and garages have forced several code changes over the years. Take gas water heaters for example. They now have to have all sorts of explosion proof safeties on them that have more than doubled the cost of conventional heaters. Garages are a particular problem as people don't realize how much flammable stuff they store in them. Gas cans, paint thinner, cars, lawnmowers, etc. These all can be potential flammable vapor sources.
    You need to verify if the heater you are purchasing is rated to be installed in an enclosure. some are only rated to be installed outdoors. as far as venting goes, you need to look at both exhaust and intake. an improperly exhausted unit can damage it not to mention fill the room with CO
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jan 2016
    TX
    157
    The manual has a nice drawing of how to pipe in proper supply air to the heater as well as spatial requirements.
