Thread: running plumbing advice
    May 2016
    Westmoreland/TN
    5
    running plumbing adviced. i originally thought the skimmer line had a clog but now after attempting to unclog, multiple ways I think the flex pvc has collapse some and possibly some cracks.
    Now to replumb. It has 1.5 inch flex pipe. I think they backfilled with gravel. Not sure about that but think they did. I am planning on digging an access hole at skimmer closest to pump and tieing in the second skimmer to new line. I want to run a new line just outside the concrete then to the pump. I think I want to run a 2 in line as much as i can. Any suggestions would be greatly appreciated. Also any insights on what the cost could be. I live in the middle Tn area
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: running plumbing advice
    We've definitely seen that happen before with flex pipe. Your plan sounds good. You don't want to run that shovel yourself for free?
    I have wondered what middle TN is, middle left to right? Or what. So, I had to google that. Who knew it was such a thing? State law, 41 counties, rules and all that. Interesting. It looks like a couple of counties got left out.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Quote Originally Posted by pooldv View Post
    Keep talking like that and this will move to the Deep End...All I know is California but recently I've been searching for the next place that will welcome my sarcastic self.
    I would never recommend flex pipe. EVER. Get rid of it and run Sch 40 (2" min).
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2016
    Westmoreland/TN
    5
    I wish I had read bout flex pipe before I installed. I thought the installer knew what he was doing he had been doing pools for 10 years.
    I was thinking the 2 inch rigid. I only have 1.5 hp motor but i think it will be fine. Going to be a pain getting through the gravel I am afraid. I think it may force me to dig a wider hole than normal just to keep the gravel from caving in.
