Thread: Testing pH and TC After Rain
    gobreeze's Avatar
    May 2016
    Davie/FL
    6
    Hi All!
    New to TFPC, great source of info and thank you so much.
    It's rained the last two evenings here and I was wondering how long I should wait to test my pH and TC after rain. Seems to me that all the rain water is close to the surface soon after a rain. I test in the early evenings which can be a problem with afternoon rain we get here in Florida.
    Thanks!
    16x30 Inground Rectangular Pool w/Spa / Plaster, 16,200 gallons / Hayward Cartridge Filter / Hayward Super Pump / TF-100 Test kit / Liquid Chlorine 10% / Hayward Poolvergnuegen Pool Cleaner / Fill from well.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Testing pH and TC After Rain
    Let it mix with the pump going for half an hour and it should be fine. You can also speed it up by brushing.
    gobreeze's Avatar
    May 2016
    Davie/FL
    6
    Makes perfect sense, thank you!
    May 2016
    Clermont, Florida
    27
    Always make sure to take the sample from at least 12 inches down as well.
    Best of luck
    You're on the right site for any issue you come across.
