Thread: When to SLAM
    natedogg's Avatar
    May 2016
    Warren MI
    22
    When to SLAM
    I've just opened my 19,000 gallon IG pool with 4 ft and 6 ft deep end and there is 0 chlorine and CYA is below 30 and PH test was yellow TA was 10 ppm, I filled half the pool with Detroit city water so that accounts for low levels. My pool is clear so I was curious if I need to SLAM the pool or just get the pH fixed, CYA up, and bleach. The pics below show the water and this was opened and filled 2 weeks ago. I figure the water should be SLAMmed because it sat so long, but it has been cold in MI and the water looks good so I'm not sure what action to take. I appreciate all insight!
    Square 19,000 gallon in-ground pool
    cartridge filter
    SWG
    intelliflo vs+svrs
    K-2006
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: When to SLAM
    You can do an overnight chlorine loss test to determine if there is a need to slam. The water looks a little cloudy to me but that could just be the lighting in the photo. Its a simple test to run and if you pass then go ahead and balance the water. Since your FC is 0 go ahead and add enough chlorine to reach 10ppm before you run the test.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    15,176
    Re: When to SLAM
    Yes, you should SLAM. First though, you need to adjust and make sure the pH is at 7.2. Anything below that is too low right now. CYA needs to be at least 30. If you still see the black dot when full, at least add another 10 ppm worth of stabilizer. Then increase FC to 12 and do everything you read on the SLAM page (link below). Good luck!
    If ever in doubt, as Zea3 stated, do an OCLT.
    natedogg's Avatar
    May 2016
    Warren MI
    22
    Re: When to SLAM
    Great info, thanks guys! I'll be fixing the pH once the robot is done cleaning and will go from there.
    cartridge filter
    SWG
    intelliflo vs+svrs
    K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: When to SLAM
    Quote Originally Posted by natedogg View Post
    Why wait? The robot will help mix things because it's moving water all the time.
    Raise TA to 50 or 60 first and give the baking soda time to mix, and then retest the pH.
